/Projects/Word Clock
word clock qlocktwo circuit schematics
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
wordclocksandwitch
bazen1
bazen2
You can see me my reflection in the glass :-)
The Middle (wood)
drvo2
The beginning
drvo6
drvo8
woodgroovesdone
woodreflectivepainting
woodedgespaintedblack
Electronics
wccpu
mainpcbdrilling
Main PCB drilling
mainpcbdone2
mainpcbdone
ledmatrixschematics
ledstrip
ledmatrix
ledmatrixinwood
wcMAX7219breakout
max7219pcb
max7219inplace
max7219soldered
addingcornerleds
wctouchsensor
P8080130
Capacitive touch sensor PCBs
at42qt1011
P8080141
P8080140
touchsensorinplace
Touch sensor PCB in place
mainpcbinwood
alldone2
All done!
The Back (hardboard)
Testing the LEDs
matrixbadleds
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,149
Rating: (2.96, votes 5112)
Date: 12-09-2012
841_word_clock.zip
Bookmark and Share Comments (222)
comment [52]
FYI, I came up with my own English translation for the clock, for anybody else who might be interested. I wrote a little script to demonstrate it for my own purposes: http://www.andrew-mcfague.com/wordclock/ This uses the same 14x16 grid.
comment [51]
@trax: Great! I was actually able to find the 1/2" version of that bit, but I have been unable to find 3/4"... I tried using a step drill bit and then smoothing out the edges, but that did not work quite as well as I expected. Do you happen to know where your friend got that one from?
IP: 67.170.78.220
comment [50]
[Part 3] The word "great" is missing from the end of comment [48]
IP: 188.221.249.49
comment [49]
[PART 2] if you could help me alter the firmware to allow the possibility to display the time such that (for example between the hours of 2 and 3 o'clock) upto half past the hour the displayed time would be "it is x minutes/quarter/half past two", and after half past the hour the displayed time would be "it is x minutes/quarter to three". My front includes the words quarter, half, and degrees just in case :-) Crazy thought..a scrolling time option (similar to date) but that just defeats the object... :-)
IP: 188.221.249.49
comment [48]
{PART 1] Hi Trax. I've generated a new English front here: http://www.mediafire.com/view/?e0wzh0zjz5zbywz . There is also an English header file at http://www.mediafire.com/?0t3tmkl447nh7n9 for this new front. I have no programming knowledge unfortunately and so, as I can't alter your firmware I have only been able to display the time as "it is x minutes past x" (as shown in the black words in my pdf upload referenced in comment [36]). It would be
IP: 188.221.249.49
comment [47]
Hi Hibs, the firmware can be changed to display something like "it is quarter to six" and so on. Currently it doesn't support it, but it is pretty easy to do that! I might do it myself, or I might help you in doing that part. The code can also be changed to display temperature in full words just like the time, IF the word "degrees" can be put to the vinyl front. All those changes are minor in the source code.
comment [46]
Hi Trax. Does this mean that you're planning a firmware change to display the temperature like "It is twenty two degrees" as well as showing it as a large scrolling display as one of your videos shows? Also, I'm still intrigued as to whether my number (2) question in my comment [39] is possible. My electronic chips are on order so I'll hold off a little in making the English front depending on your responses. Can't wait to build your clock!!
IP: 188.221.249.49
comment [45]
No, there is no "degrees" in original :)
comment [44]
So, the word "degrees" is only in english? There's no word "stupnjeva" in original text. :)
IP: 85.114.60.85
comment [43]
Hi Hibs, oh crap, I forgot about the *teen numbers... :-) Back to the beginning... The word degrees is there so we can display the temperature like: "It is twenty two degrees".
Comment page: <...17181920212223>
