comment [81]
- From Rafał on 21-11-2012 at 16:08:29
Hi, I have a question ...Is it possible to make the clock to be 24h?and whether it is
sufficient to add another hour to the header file in the source code.
IP: 89.79.141.159
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,153
Rating: (2.96, votes 5135)
Date: 12-09-2012
It is possible to make it 24hour, but where would the letters fit? And what do you mean by
adding another hour in the header file? You mean another language? English language is under
construction...
IP: 89.79.141.159
Znam sta je sve to ali na poslu nemam kad da citam DS, samo letimično a kod kuce dvoje
mladunaca trazi svoje...vidjeces kad se ozenis :-)
Znas sta je monostabil i sta je RS flip flop, a nisi mogao skontati o cemu se radi iz
dokumentacije? Kod ovog AT42QT1011 izlaz je logicka jedinica kada je detekcija prisutna. Kada
odmaknes prst sa senzora on izlaz prebaci na logicku nulu (GND).
Trax, kakva su tvoja iskustva sa ovim AT42QT1011?
Ne skontah dobro iz datasheet-a, jesu li izlazi tipa monostabila ili RS flipflop?
Hi Trax. I've noticed that the specified accuracy of the DS3231 chip is +/-3 degrees Celsius.
Do you think it is possible to adjust the firmware to enable the user to add or subtract a
'calibration number' so that the correct absolute temperature is displayed?
IP: 188.221.249.49
Hi topbanana, if I remember correctly - I put 220uF/16V on main board and 47uF/16V on LED
driver boards. It is not that critical, don't worry about it...
Trax, can you clarify the capacitor on the mainboard. The PCB files say 100uf/16v but you photo
show 220uf/16v.
Also what size is the capacitor on the driver board?
IP: 83.100.232.60
