comment [91]
- From Rafał on 23-11-2012 at 15:40:34
Can I replace the AT42QT1011 to this AT42QT1010-TSHR without any changes?
IP: 89.79.141.159
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,153
Rating: (2.96, votes 5135)
Date: 12-09-2012
Yes you can. P.S. Check these out: http://bit.ly/R5nvWX http://bit.ly/TgdyCd
http://bit.ly/R5nLFC http://bit.ly/UOOEbZ
IP: 89.79.141.159
The light sensor is automatically calibrated in clocks firmware. For light sensor you can
choose a simple CdS cell, like this one: http://learn.adafruit.com/photocells
What are requirements / parameters for the light sensor?
IP: 89.79.141.159
This stupid CMS is removing the word "de le te" from my comments. You must REMOVE
those two lines :)
Well, you must find 4 spare pins on microcontroller that will control the 4 dots - or use 1
spare pin and a transistor to turn on 4 LEDs at the same time. Next, find the display_time()
function and two lines "if( time_h == 0 ) time_h = 12;" and line "if( time_h
12 ) time_h = time_h - 12;" and that's it! There will be some more small changes with the
dots but thats it.
I write from 00: XX to 23: XX? But where in the source code I have to change something so that
it can display 24 hours and handle a full display 16x16 and how to convert dots the output of
the uC?
IP: 89.79.141.159
You can add up to 23h, since 24h = 0h :) It has to be changed in source code also (.c file) but
it is not a very big problem!
I am thinking the Polish language, in file "lang_ba" are written / / array Hours 01:
XX to 12: XX, or just add there to 24: XX if I am wrong I would really ask for information or
changing the code
IP: 89.79.141.159
