comment [101]
- From edotz on 06-12-2012 at 21:10:15
@trax Moze li se dobiti link sa e-bay, sa kojeg si nabavio diode, i ako nije tajna, koliko su
kostale?
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,153
Rating: (2.96, votes 5135)
Date: 12-09-2012
Idi na ebay i upisi u pretragu: 170807658401
kostale?
I should have them in stock in a month or so - if you can wait! I am testing them right now.
hello trax! nice work. I am currently working on a French version. I understand that you do
make PCBs by a company. I would like to know where to order if possible. thank you
IP: 70.27.244.215
You will need 5V 1A power supply! I use 220V / 5V 1A from my old wireless access point.
Hvala @Rotek, to su podaci koji su mi bili potrebni, a posebno ovo 2300 mcd. Hvala jos jednom.
@edoTz
dioda je 3.0-3.2 V, 20mA, 2300mcd, kut 120 stupnjeva
Kakva bolan kataloska dokumentacija, iluminacija,... to je NO-NAME dioda sa eBay-a :)
Odlican projekt! Interesuje me koje si konkretno ledice koristio i kolika je njihova
iluminacija prema kataloskoj dokumentaciji???
Pozdrav
IP: 89.146.145.211
