comment [111]
- From trax on 10-12-2012 at 10:28:53
FIX: Also function display_clear() - remove entire body of "if( preserve_dots )".
That's it.
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,153
Rating: (2.96, votes 5135)
Date: 12-09-2012
Hi Trax, do you know where I can buy the DS3232N chip, I mistakenly bought the DS3232SN (not
enough pins on that) Cheers.
IP: 94.196.150.198
That's it.
Font is: DIN (DIN Pro). You can use PORTD.1 to control the fourth corner LED. In source code,
you need to change the body of two functions: "dot_on()" and "dot_off()".
It should simply turn ON appropriate PIN for your corner LED. I don't have the time right now
to do it myself. Also function display_clear() - entire body of "if( preserve_dots
)". That's it.
I forgot, as it is called font that you used?
IP: 89.79.141.159
Hi,1st - The diagram are 3 free uC pins, I want to use one of them to the blinking dots will be
connected by a transistor,2nd - What needs to change and how to wykożystać to display two
lines that are not usedI do not know how to do this programmatically, please help.
IP: 89.79.141.159
LEMEMBRE: Wow, 10 clocks? That is too much work :-)
You can get PCBs from www.batchpcb.com (sparkfun) !
Imas izvorni kod u projektnim fajlovima, pa prekopiraj sebi kod.
@trax Kako si rijesio shifting rijeci sa desna na lijevo kad ispisuje ono datum, vrijeme itd.
obzirom da ja pisem program za PIC pa mi treba neka orjentaciona logika na koji nacin si to
izveo????
I could wait but I am like a child I would have it now. ;) And I want at least 10 clocks is for
this reason that I asked you where you have placed your order. Best Regards from canada
IP: 70.27.244.215
