comment [121]
- From trax on 16-12-2012 at 22:06:30
Ma neces nista sprziti, samo nabavi sve sa sheme i probaj :-)
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,153
Rating: (2.96, votes 5135)
Date: 12-09-2012
Trax, double checked everything over the weekend, the chip I have is marked DS3232SN 16 Pin,
but I should have looked at your pictures properly and realised that the top two rows on the
PCB are not connected to the chip! Sorry for the confusion, I should be close soon to
connecting everything up, just need to learn how to program now!
Nisam baš siguran u svoje znanje, pa mi nekako bilo sigurnije da pitam... Ne bih da spržim
nešto greškom... :)
@Paul: There is no DS3232SN with 16pins available!!! Do you have IC in your hands so you can
count the pins??? You can use DS3231 which has 16 pins because the clock IS compatible with
DS3232 (20pins) and DS3231 (16pins) !
@LEMEMBRE: it is not public yet, I need to make sure they have no mistakes first. I am milling
this clock on CNC right now, but soon I should verify the boards.
@marxman: valjda mozes sam izvuci spisak dijelova iz sheme???
Pozdrav Trax! Gde bih mogao da nadjem spisak svih delova potrebnih za izradu sata. Koliko
kondenzatora, otpornika, tranzistora i cega vec ima... ? Hvala!
thank you I have looked at the website but I did not find your pcb and they demand the gerber
file type. Your order was open to the public? best regards
IP: 70.27.244.215
Hi, thanks for the fast reply. Just to clarify, I ordered a DS3232SN which has 16 pins by
mistake, your system requires a 20 pin chip which is the N version? All the ones listed on eBay
are the SN (16pin) version. If you are able to find the correct one with a link I would be most
grateful. Thanks in advance for all you help so far.
IP: 94.196.150.198
What do you mean not enough pins? It is 20 pins, SOIC (wide) package? Anyway, you can buy it on
eBay. Try finding DS3231 instead, it is compatible with DS3232 and its cheaper!
