comment [131]
- From trax on 10-01-2013 at 15:34:47
Pielo, I will need to check when I get home. Have you connected everything else?
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,153
Rating: (2.96, votes 5135)
Date: 12-09-2012
not all, the four MAX7219 in series but this is not a problem. i don't understand the part with
the corner led's.
IP: 178.0.247.115
if you can say me exactly to which pins you corner dots has connected?
IP: 62.159.22.218
Those pins are "pin headers" - google it. I actually never used the AUX pin, so you
don't need it! It was for experimenting...
Thanks for that Trax, one last question for now (honest!) What are the ISP (x 6 Pins) and the
Spare (x 3 Pins) for, also when would you use the Aux Max7219 pins? Cheers.
It is connected with a small wire (you can't see it) that goes through the wood.
If you made a double-sided PCB with copper back and parts on the other side, then you simply
connect that copper area with the input for the touch panel. Drill the board and solder a short
wire through them holes and that's it :)
Trax, on the touch sensor I have made the PCB which has a copper back, but one of your pictures
shows a separate front piece, how is this connected? Cheers.
IP: 188.30.116.97
Atmel treba da bude cist, bez bootloadera ili sa bootloaderom kojeg ces pregaziti sa HEX fajlom
kojeg imas u attachmentu. Mozes kompajlirati i svoj HEX ako ces vrsiti neke izmjene u kodu...
Ovi INCLUDE dodju uz kompajler, tacnije uz AVR Studio kojeg ces skinuti sa atmel.com
Trax, dva laicka pitanja. 1. U fajlu wc.c pise #include stdio.h
#include avr/io.h
#include avr/interrupt.h
#include avr/pgmspace.h
#include stdlib.h // just for random nrs
#include avr/eeprom.h
#include string.h
ali tih fajlova nema u zipu...
2. Da li ATmega treba da ima bootloader ili da bude cist?
P.S. Prvi mi je mikrokontroler koji cu da probam da ozivim pa sam zato u "nebranom
grozdju"... :)
Yes, that is correct - just solder it and it should work.
