APR28
Sip and Puff iPod Dock Controller
By definition, Sip and Puff technology is a method used to send signals to devices using air pressure by sipping (inhaling) or puffing (exhaling) on a tube.
Detecting positive and negative air pressures in that tube can be done by using an air pressure sensor, the resulting pressure can be read from a sensor with ADC input pin of a microcontroller where in turn the microcontroller can control some device. In this case, that device is an iPod and the project name is Sip-n-Puff Arduino Shield.
Be sure to check the video where the author explains this method using Arduino in details.
© Bob Johnson
- Car turn signal controller (19-12-2008) [@News]
- GSM controller v2 (16-10-2005) [@Projects]
- PC controller (29-12-2004) [@Schematics/Everything else]
- Phoneline controller v1 (20-12-2007) [@Projects]
- Temperature controller (23-02-2004) [@Schematics/Everything else]
- GSM controller v1 (22-04-2004) [@Projects]
- Phoneline controller v2 (14-01-2008) [@Projects]
- SMS controller with AT90S2313 (24-08-2004) [@Schematics/Microcontrollers]
- Motor speed controller (23-02-2004) [@Schematics/Everything else]
- LPT Stuph controller (30-11-2008) [@Programs]
