- From stevan vlasinac on 18-10-2012 at 20:46:54
Postovani dali ima neka jaca sema da blokira mobi signal u precniku do 20-30m, molim za pomoc
neko ko ima nek je objavi ili nek mije posalje na mejl.
FEB7
Here is a very simple plan to make a "dirty transmitter" that is also known as Cell Phone Jammer.
It is based on NE555 as simple noise-maker whose output is fed to a single transistor oscillator. The oscillator is designed to operate between 800MHz and 2GHz which happens to be the frequency span used for GSM phones. The frequency of operation is set with a trim-capacitor.
The battery should last no longer than 1 hour and the range of jamming is around 10-15 feet.
Ovaj bi do 30 metara, a ovaj drugi bi da mu neko javlja na mail. Ne budite lijeni i dokoni vec
semu u ruke i konstruisite a ovom prvom preporucujem modifikaciju parametara seme i vece
napajanje svakako.
IP: 109.175.56.100
molim vas ako pokusate da mi javite rezultate na dr.cumpek7@gmail.com, hvala unaprijed!
