SEP13
Glass PCBs
If you ever fantasied about making your own PCBs from scratch, but really from scratch - this is the thing for you.
Here we are not talking only about etching a PCB but the actual manufacturing of PCB material. By using a thin copper sheet which is actually intended for PCB manufacturers, some UV glue and a glass (yes, a glass microscope slide) as a substrate it is pretty easy to make a fully transparent PCB. In this video that lasts 20min we can see how this thin 1-ounce copper sheet is glued to the glass to form a PCB material. After that the well-known etching process is started to make a fully transparent glass PCB.
© by CNLohr
[ Source: CNLohr ]
- How to make killer PCBs and solder paste stencils (21-04-2009) [@News]
- Toner transfer PCBs and copper tinning (23-04-2009) [@News]
- Render PCBs with Eagle layout editor and POV-ray (31-01-2009) [@News]
- Liquid level measurement (in a glass) (10-12-2008) [@News]
- PCBs for Inductive Vehicle Loop Detector available for sale (25-10-2015) [@News]
