/Projects/Warm Tube Clock v2 - Nixie Clock
This is a new and improved version of "Warm Tube Clock" - the open source Nixie clock project. Important hardware changes between this new version and the previous one are:
- Timekeeping is more accurate and is done by DS3231 (or DS3232) RTC IC
- There is no DS18S20 temperature sensor - the internal one of RTC IC is used instead
- Backup battery is not powering AVR anymore, but only the RTC IC
- There is no "slide switch" to control the alarm - now it is done in firmware
- Crystal on PCB is optional and can be chosen up to 16 MHz. It clocks AVR and GSCLK pin of TLC59401 IC
- Pin-compatible with previous version of Nixie "shields"
So, if you didn't read about the previous Warm Tube Clock, it is best to do it right now.
All project files (schematics, PCB & source code) are available for download by clicking on the red download button under the article (open source hardware).
UPDATE: Project is on Hack-a-Day and Hacked Gadgets :-) !
UPDATE 06-03-2011: New firmware added.
UPDATE 28-11-2014: PCBs are available for sale at link: http://www.elecrow.com/warm-tube-clock-v2-pcb-board-p-1154.html.
UPDATE 10-06-2015: Forum discussion is on this link.
New firmware options
1. time display
2. date display
3. temperature display
4. seconds display
5. configurable times of showing for all of above (for example, the clock can display time for 20 seconds, and move to next thing to display: date, temperature or both and go back to time. It can even be set to display only the temperature)
6. configurable Nixie tube brightness
7. configurable color of bottom RGB LEDs that blink at 1/2 Hz rate (or even turned off)
9. fading tubes while showing the date for better understanding of what is on display (MM.DD and YYYY)
15. cathode anti-poisoning on every 5 minutes
16. 12-hour and 24-hour mode for time and date, temperature conversion to Fahrenheit
main board v2 - top side
main board v2 - bottom side
Design changes
This version of clock uses DS3231 RTC IC and is fully compatible with DS3232. There were few different methods of how this IC could have been used in this project. I chose to use it's SQW pin to generate an interrupt in AVR each second (1 Hz precisely). So, on every SQW impulse the AVR reads RTC data (I2C) from DS3231/2 to display on tubes and for other things. Note: you must solder the SMD jumper on PCB in order to use currently supplied firmware. This jumper connects SQW pin to AVR.
DS3231 RTC IC is now where "slide switch" used to be
Second method is much simpler - supply AVR's OSC1 (PB6) pin with 32 kHz output of DS3231/2 instead of using 32.768kHz crystal. This way the AVR would get extremely accurate 32.768 kHz clock for incrementing the Timer1 of previous version of firmware. In that case, no I2C routines would be necessary.
Third method would be not to use SQW or the 32 kHz output, but to read RTC data (with I2C) in a program loop at all times. There is that SMD jumper on board so you can disconnect the SQW pin to use this method.
Part of the schematics with DS3231/2 RTC IC
Nixie shields
New version of clock is pin-compatible with previous one, so it is possible to use shields of previous version on this one and vice-versa. In this new version of clock, IN-8 shield is replaced with IN-14 shield because these tubes are cheaper and easier to find.
IN-14 Nixie shield
TLC59401 is at the bottom side of IN-14 Nixie shield
Under the Nixie tubes there are 4 SMD RGB LEDs
These IN-14 tubes are same as IN-16, only much bigger.
HV voltage booster
Voltage booster has remained the same. But if you are using (for example) 12 MHz crystal to clock the AVR, then the frequency of PWM signal is 46.875 kHz (FREQ/256). Using crystal of higher frequency will also result in a smoother RGB LED effects. You can experiment with the coil value and power supply to achieve minimum heating of the booster circuit. When powering clock with 11 V you can use coil of around 680 uH or even less (@ 12 MHz).
Nixie dots (semicolons)
Nixie dots are actually ordinary neon indicators from a 110/220V switch as you can see in the picture bellow.
Nixie dot harvesting
Thermal images of PCBs
Warmest point: 36°C, coldest: 21°C. Thanks to Filip for these images!
3D printed enclosures
Thanks to Filip for this! Files can be downloaded from his blog article on this link.
Image and video presentation
Image with blue LEDs
Video without bottom LEDs + at night
Video
AM/PM setting example
Nixie cross-fading example
Nixie cathode anti-poisoning
Download counter: 3,145
Rating: (2.93, votes 4806)
Date: 02-06-2011
Lokalna verzija ove stranice: Warm tube clock v2 - Nixie sat
- Warm Tube Clock v2 - User pictures (11-08-2011) [@News]
- Solid wood block digital LED clock (17-01-2009) [@News]
- Warm Tube Clock v1 - User pictures (06-05-2011) [@News]
- IN-8 single nixie tube clock (26-08-2009) [@Projects]
- Warm Tube Clock v2 - Nixie Clock with 4 tubes (03-06-2011) [@News]
- Plasma ball with nixie tube (16-07-2009) [@News]
- Alarm clock with accelerometer and propeller chip (30-09-2011) [@News]
- Nixie clock - Millivolt Meter Hack (26-10-2011) [@News]
- Warm Tube Clock - Nixie Clock with 4 tubes (27-11-2010) [@News]
- Master Clock driver for antique slave clocks (05-05-2016) [@Schematics/Everything else]
- From Robert on 03-06-2011 at 01:49:40
Looks like the V1.0 tube shields will work with the V2.0 controller board...I hope so?....Can't
wait to get a set of the V2.0 boards...The new design is a vast improvement over the old
version....Thanx for all your work TRAX....regards...
IP: 24.231.144.250
