NOV27
Warm Tube Clock - Nixie Clock with 4 tubes
Clock works at voltages from 7.5V to about 14V and consumes around 200mA. The PCBs are 10cm x 3cm, so pretty small. Beware that it generates high voltages of around 200V so don't touch anything while it is operating.
- Solid wood block digital LED clock (17-01-2009) [@News]
- Warm Tube Clock v2 - Nixie Clock with 4 tubes (03-06-2011) [@News]
- Electromechanical Nixie Clock (09-07-2010) [@News]
- POV Propeller Clock Build (23-08-2010) [@News]
- Warm Tube Clock v2 in Housing - User pictures (14-09-2011) [@News]
- Neon tube blinker (23-02-2004) [@Schematics/Optics]
- PCBs for Warm Tube Nixie Clock v2 (03-12-2014) [@News]
- Warm Tube Clock v2 - User pictures (11-08-2011) [@News]
- Nixie clock - Millivolt Meter Hack (26-10-2011) [@News]
- Word Clock (12-09-2012) [@Projects]
