/Projects/Warm Tube Clock v1 - Nixie Clock
Clock works at voltages from 7.5V to about 14V and consumes around 200mA. The PCBs are 10cm x 3cm, so pretty small. Beware that it generates high voltages of around 200V so don't touch anything while it is operating. It shocked me few times and I dropped the clock on the table (no damage done to me or the clock).
in16b
UPDATE: Project is on Hack-a-Day, ...and now also on HackedGadgets, and on TubeClockDB, whoho :-) !
UPDATE 6/2/2011: New version of project!
main2
main4
So here are the clock's options:
1. time display
2. date display
3. temperature display
4. configurable times of showing for all of above (for example, the clock can display time for 20 seconds, and move to next thing to display: date, temperature or both and go back to time. It can even be set to display only the temperature)
5. configurable Nixie tube brightness
6. configurable color of bottom RGB LEDs that blink at 1/2 Hz rate (or even turned off)
7. the "temperature color blender" option that displays blue color at lower temperatures, red at high temperatures and mixes these two colors between these extremes (or even turned off)
9. fading tubes while showing the date for better understanding of what is on display (DD.MM and YYYY)
15. cathode anti-poisoning on every 15 minutes
in8e
Few notes about the design
After seeing a few RGB LED projects around the web with the TLC5940 IC I decided to give it a try by using it to multiplex the Nixie tubes and drive RGB LEDs at the same time. I chose the SMD version TLC59401 and after some trial an error I managed to make it work, and it works great. The interrupt routine inside AVR sends new data to TLC59401 in a configurable periods of time (refresh rate). This rate is different for each model of Nixie tube, so for IN-16 tubes slower rate is required than it is for the IN-8 tubes. Advantage of using the TLC IC to multiplex Nixies is that it is possible to adjust each Nixie tube with a different brightness quite easily.
The power booster is just like the one used in the Ice Tube clock but with feedback option (I can safely say that this clock is pretty much inspired by the cool Ice Tube clock). The AVR has no clue of what duty cycle it must set for the PWM output to generate the required voltage, so it reads back the voltage produced on the HV output and increments the duty cycle until required voltage is produced. This way the value of coil in booster circuit is not firmly defined.
Power supply unit (5V)
psu
main3
The power supply unit has a self-resettable fuse that will cut the power if things get freaky and restore the power once it cools down. The PSU has three outputs +9V, +5V/1 and +5V. The +9V is used in HV voltage booster section and is actually whatever you supply the clock with (from the power source), the +5V/1 is used to power everything on-board except the AVR. The AVR is powered by +5V source which is battery backed-up, meaning that when power gets lost the AVR will continue working on 3V button cell battery. These two "separated" 5V power supplies are done by using three 1N5817 high-speed diodes.
HV voltage booster
booster
in8c
This circuit is a basic boost converter (step-up converter) device just like the one you've read about here http://en.wikipedia.org/wiki/Boost_converter. The coil used in this circuit is 1200uH (any value around 1000-1200uH can be used) from Coilcraft. The PWM frequency used for booster MOSFET switching is 31.250 kHz with different duty cycles for different output voltages. The high voltage builds up in the storage capacitor C13 and is being measured by AVR through the voltage divider circuit formed by R3 and R4. Nixie tubes get their needed high voltage (the current actually) through a current limiting resistor R5 and they are protected with Zener diode ZD1 200V. The high voltage is further being filtered with capacitor C14 which is actually not mandatory (I never soldered it and the clock works like clockwork). The Zener diode is optional but it is recommended. Any generated voltage higher than ZD1 voltage (200V) will be spent on resistor R5 which will cause it to heat up. If the clock can't produce required voltage upon startup, it will report this by beeping and blinking all LEDs in red color and will stop working (go to sleep). However if it produces over-voltage, it will reduce the voltage to below requested value and report this by blinking all LEDs in orange color, but the clock will continue working. To fix this, another power source with slightly different voltage usually does the trick. If that doesn't work out, another coil should be used.
Nixie cathode driver
cathodedriver
Nixie tubes that show digits have 10 or 11 cathodes for all numbers 0-9 and an optional dot. To save pins on the AVR, a BCD decoder is used. This is not an ordinary BCD decoder because it can withstand high voltages used to power the Nixies. This driver is IC2 K155ID1 which is a 74141 equivalent. It has 10 outputs for 4 BCD inputs. Between two middle Nixies on the top board there are two "colon" neon bulbs (small Nixies) also working on high voltage. These two are "driven" by two NPN high voltage transistors T1 and T2 MPSA42.
Beeper and temperature sensor
beeptemp
1002871
The beeper is a small speaker just like in your PC's mainboard. A piezo speaker can also be used here, but the sound will not be as fuzzy as it is with PC speaker. It is driven with a BC547 NPN transistor and volume is adjusted with R10 resistor. The sound is produced on AVR's pin PB1 (OC1A) by software - not hardware PWM. The alarm sound melody is user-adjustable in wt.h header file.
The temperature sensor is Maxim-IC DS18S20 and is directly connected to AVR's appropriate pin. The 1-wire library used in this project is not interrupt-safe, meaning that the 1-wire data transmission will be interrupted sometimes by ISR routines and will produce invalid temperature readings (00.5 degrees). This can be fixed in the source-code by disabling interrupts in certain parts of the source-code. This, however, I didn't do since it can produce display flickering during temperature readings.
Both the beeper and temperature sensor are supplied by IC2 7805 stabilizer and do not consume any power from the backup battery.
ISP port and buttons/switch
ispbuttons
in8d
The clock is controlled with just two buttons and a switch. Switch is used to turn on/off the alarm. The buttons are used to request the temperature and date to be shown, enter the settings menu or activate the "candle mode".
The clock can be (re)programmed without taking out the AVR chip with this standard ISP port. Before programming, make sure that the switch SWALARM is turned off (disconnect state). Also make sure to disconnect the programming cable from the ISP connector after programming, or display flickering and "ghosting" effect can be seen on Nixie tubes while clock is working.
ATMEL AVR brain
mcu
main1
The brain of the clock is ATmega328P AVR microcontroller (the datasheet says it works at low voltages as 1.8V, and this is great because it must continue working on 3V backup battery). The important thing to notice here is the external crystal of 32.768 kHz that is used to clock the internal Timer1. That timer is set with a prescaler of 128 so that it generates interrupt once per every second and that is used for internal RTC. For some reason the AVR doesn't interrupt on every second, but slightly faster (not ideal). So, the capacitors C2 and C3 around the crystal should be adjusted for the smallest error, meaning you should put a variable capacitors here, or experiment with these values to get best (near to ideal) results. You can also use ATmega168 if you strip the source code to bare minimum (not using A/D feedback voltage measurement, and commenting out the "temperature color blender code" would be a good start). Another thing to notice here is the CLKO output of the AVR. Yes, this output is used to export AVR's internal clock signal and is used to clock the TLC59401 on the upper "Nixie shield" board.
Nixie anode & RGB LED driver
tlc59401
in8g
The anode driver for Nixie tubes is made with NPN optocouplers OPT1..OPT4 TLP627. These optocouplers can withstand "Vce" voltages of more than 200V which is required. They are used in "common collector" configuration aka emiter follower / voltage follower because Nixie tubes don't draw much current and this seams efficient. I have seen this kind of usage of NPN optocouplers in other Nixie tube clocks and it works like a charm. When Nixie tubes are displaying numbers, these optocouplers are being switched in high speed providing anode voltage to one Nixie tube at a time. That is called multiplexing. They are switched by the Texas Instrument's excellent IC TLC59401 and on it's remaining 12 outputs (16 in total) there are 4 RGB LEDs with common anode. The interrupt routine in the AVR refreshes the TLC59401 IC all the time thus sending new data to all LEDs and all optocouplers. Driving the TLC59401 IC is pretty easy once you figure out how. There are 7 inputs that require our attention; GSCLK pin - this pin needs to be provided with a constant clock; BLANK pin - on every 4096 impulses of the GSCLK signal it requires a small impulse that will reset it's internal counter; XLAT pin - this pin has to be triggered whenever new data is clocked in (this is done together with the BLANK pin); MODE pin - this tells the IC if the incoming data is Data or Command; SCLK, SIN pins are for sending data over SPI bus. The important thing to note about the TLC59401 is that you must solder the bottom pad to GND. If you fail to do that, the chip will not work properly or at all!
Nixies
nixies
in8a
in16c
shields
On the upper board (the Nixie shield) there are four Nixie tubes and there are two shield designs for two different Nixie tubes: IN-16 (smaller in size but much more beautiful) and IN-8 (medium sized). Between two middle tubes there are two "dots" or "colons" which are controlled individually so when showing the temperature only upper "dot" is lit, and when showing the date only bottom "dot" is lit. These "dots" are actually a very tiny neon indicator bulbs that you can find in wall sockets, indicator lamps or voltage testers. Luckily they glow in the exact same color as Nixies. Cathodes of all Nixies are connected to the outputs of K155ID1 (74141) and cathodes of "dots" are connected to two NPN transistors MPSA42.
Alarm test and "menu" presentation
Changing some settings on the clock
Introduction and overview of the clock
Nixie Digits - Cross Fading Example
See more images on Flickr
Download counter: 40,432
Rating: (2.98, votes 4899)
Date: 17-11-2010
Lokalna verzija ove stranice: Warm tube clock v1 - Nixie sat
786_warmtubeclock.rar
Bookmark and Share Comments (61)
comment [51]
Great information! I have two questions: 1. You do not seem to use the GSCLK signal at all in your code to give a reference clock to the TLC59401 PWM control. Correct? 2. You put SMT LEDs under the IN-16 white spacers. Do you need to modify the spacer in any way to let the LED shine through? Thanks for all your efforts with this clock.
IP: 139.142.107.9
comment [50]
uspješno sam isprogramirao čip i sve lijepo postavio na pločice (osim samih cijevi) i sve skupa ne radi. Greška je vjerojatno što sam sam izrađivao pločice fotopostupkom što vjerojatno nitko nije. Jednostavnije je i manje živaca košta dati nekoj firmi koja se bavi izradom takvih profi pločica.. @trax imaš li par pločica da mi prodaš? da probam sa njima. Jer elemenata imam za nekoliko satova a izrađivanje pločica nema šanse da ponovim.. Javi mi na email ako imaš.. Pozdrav!
IP: 195.29.242.36
comment [49]
Koristim interni 8MHz oscilator za rad mikrokontrolera, a eksterni 32khz koristim za povecanje internog Timer-a koji mjeri (cuva) vrijeme. To je klasika...
comment [48]
Može jedno pojašnjenje? zašto koristiš interni oscilator na 8 MHz (prema screenshotovima u prilogu)? zar se nebi trebao koristiti ovaj kvartz za 32 kHz za klokiranje atmela kao vanjski oscilator? Podešenje fuse bitova je za taj slučaj drugačije...
IP: 93.136.231.157
comment [47]
Pa prebaci se na AVR Studio i on ce ti napraviti validan Makefile kojeg onda mozes pokretati iz svog AVR Dudeta :)
comment [46]
Krivo sam napisao - pokušaj kompajliranja je bio u avd-dude-u, a program je pisan u programmer's notepad-u, zato što je to okruženje u kom inače pišem programe.. ali nema mi druge neko pokušat ovo šta kažeš - prebaciti se na studio!
IP: 195.29.242.36
comment [45]
AVR Studio je razvojno okruzenje a WinAVR je kompajler. Nisi mogao koristiti jedno umjesto drugog... Ja sam ovo pravio u AVR Studio a kompajler mi je WinAVR bas kao sto je kod tebe, i sve radi bez problema. Znaci, instaliraj AVR Studio i instaliran WinAVR. Otvori projekat u AVR Studio i klikni COMPILE :-)
comment [44]
Ovaj tekst je preveden s engleskog: Koristio sam AVRStudio4 s AVRToolChain prevesti koda. I onda koristiti AVRDude s USBtinyISP za program AVR i postaviti osigurači. Koristeći Atmel toolchain rezultiralo manjim binarna datoteka. Čini se da su bolji od optimizacije pomoću WinAVR kao prevodilac.
IP: 198.95.226.224
comment [43]
Sastavio sam hardver i sad pokušavam kompajlirat kod. Reci može li se ovaj tvoj source kompajlirati s WinAVR-om? jer ja ne uspjevam. Kad napravim makefile, zadam mu target file wt.c , dodam pod list of c-files onewire.c (i wt.c naravno), kad pokrenem gcc on javlja da "no rule to make target 'main.elf'" U čemo sam pogriješio? zašto ne može generirati izlazne datoteke? dal je to zbog korištenja Win AVR-a umijesto avr studija? --tako sam blizu a tako daleko :):) Pozdrav!
IP: 195.29.242.36
comment [42]
@trax Neke CD72P (japanci), a to sa eBay slabo funkcioniše u Srbiji.
IP: 79.101.208.236
Comment page: <1234567>
How much is 7 + 1 = also add letter "a" at the end of your result! Eg.: 7a
