APR26
Dual channel IR remote control published
This project is very similar to previous one: IR light dimmer v1. The reason for building this device is primarily because incandescent light bulbs are being widely replaced with fluorescent power-saving ones.
So, the differences between dimmer and this device are that it has two channels, it can't be used for light dimming and it can control those power saving fluo-bulbs which have internal electronics/converters. The controlling element is solid state relay (SSR) which consists of opto-triac MOC3043 (MOC3042) and a triac (ie.: BTA16, BTA08, ...). This combination enables us to turn ON/OFF all kinds of appliances (motors, lights, heaters, boilers, PC...).
Features of current beta version of firmware: controlling two independent appliances via remote controller and wall push-button, double-click on the push-button controls second channel B, learning IR codes from RC5 and NEC remotes, two modes of operation: Toggle and ON/OFF, sleep timer in duration of 2 minutes.
Project page
[ Source: Elektronika.ba ]
Dvokanalni IR prekidač objavljen
Link
- From trax on 18-02-2011 at 19:00:51
Klasicno programiranje, bas kao za dimmer. Ili ga znaci nisi dobro isprogramirao, ili ti je
neka komponenta crkla.
comment [14]
- From 178.223.47.3 on 18-02-2011 at 17:25:55
OK.Probacu ponovo da isprogramiram pa cemo da vidimo,crko mi kineski instrument pa malo cekam
za kupovinu drugog,ali probacu ponovo da ga programiram.Vezano za icprog dali potrebno neko
podesavanje za pre programiranja ili samo na program all.Uvek sam isao samo na program all kod
irdimmerV1 nisam imao problema.
IP: 178.223.47.3
- From trax on 18-02-2011 at 15:16:26
Jesam, to sam ja pravio. HEX fajl koji dodje uz shemu je korektan i uredjaj mora da radi ako si
sve dobro sklopio i isprogramirao.
- From 213.244.236.3 on 18-02-2011 at 14:17:36
Znam zato i kazem da ne svetli,kad pritisnem taster.Nista se ne desava.
Zato i sumljam u mikrokontroler.Dali ste vi ili(ti) pravili ovaj uredjaj i dali je
mikrokontroler radio uz isti program?
IP: 213.244.236.3
- From trax on 18-02-2011 at 10:08:32
LED bi trebala da svijetli kada taster pritisnes - tako ces znati da li si dobro isprogramirao
PIC.
- From 178.223.47.3 on 18-02-2011 at 09:26:10
Napajanje provereno izmedju pinova 1 i 8 5v.
Koristio sam MOC3043 blok condenzator od 0,47mikrofarada i tiristor BTA16-600 i sve ostalo po
semi ,pravio sam light dimmer V1 i sve je proradilo iz prve.
Izgleda da moc ne dobija struju od mikrokontrolera pa nece da ukljuci tiristor.
IP: 178.223.47.3
- From trax on 18-02-2011 at 08:02:54
Mozda ga nisi dobro spojio na napajanje. Mozda ti neka komponenta ne radi kako treba. Koji si
MOC optocoupler koristio? Sta se desava kada pritisnes dugme/taster? Opet pazi, jer na sklopu
je uvijek prisutno 220V!
- From Drax on 17-02-2011 at 16:59:41
Kad ukljucim nista se ne desava.
Na izlaznom pinu br 2 ne svetli led dioda.
Isti mikrokontroler sam probao u ir dimmerV1 i radio je korektno.
Sve je povezano po semi.
Da li bih mogao dobiti kratko objasnjenje o mikrokontroleru i kako on radi.
Ubacivao sam vise puta hex file skinut sa neta od dvokoanalnog ir prekidaca,ali nista.
Pozz.
IP: 178.223.47.3
- From trax on 17-02-2011 at 15:31:50
Pa ako sumnjas na program, re-programiraj ga. Inace, daj opisi sta se desava kada ga ukljucis.
- From Drax on 17-02-2011 at 14:13:55
Sastavio sam uredjaj ali neuspesno mislim da je u pitanju program mikrokontrolera.Pomoc
IP: 178.223.47.3
