APR13
Geiger Counter with Arduino and LCD
If you ever needed a Geiger Counter but couldn't find one, why not build it yourself? Geiger Counter is a very simple device but having in mind that it requires very high voltages for operation it might get tricky to interface it to a microcontroller and even have it operating on batteries.
Here is a Geiger Counter project that is hand-held, operates on batteries, has LCD display for visual and piezo beeper for audible particle detection notification. It uses Arduino for digital processing and for the detecting part - SSBM-20 GM tube is used. Anyone trying to build this device should bare in mind that it uses high voltages (around 500V) that are generated with a simple boost converter with NE555.
I also found an interesting video introduction to a Geiger Counter device so make sure you don't miss it.
[ Source: BroHogan ]
- Dice value readout using Arduino AVR (22-09-2009) [@News]
- Croatian Arduino - Croduino by e-radionica (22-03-2016) [@News]
- Object counter (24-02-2004) [@Schematics/Everything else]
- Morse Code Generator with Arduino (28-09-2015) [@News]
- Geiger counter v1 (20-03-2004) [@Schematics/Everything else]
- LIDAR gun tester with Arduino (16-11-2009) [@News]
- LED flickering with Arduino (18-05-2009) [@News]
- Event counter (23-02-2004) [@Schematics/Everything else]
- LCD winamp plugin on USB (03-12-2008) [@News]
- Frequency Counter (30-11-2008) [@Programs]
