/Projects/Dual channel IR remote control v1
This project is very similar to previous one: IR light dimmer v1. The reason for building this device is primarily because incandescent light bulbs are being widely replaced with fluorescent power-saving ones. So the differences between dimmer and this device are that it has two channels, it can't be used for light dimming and it can control those power saving fluo-bulbs which have internal electronics/converters. The controlling element is solid state relay (SSR) which consists of opto-triac MOC3043 (MOC3042) and a triac (ie.: BTA16, BTA08, ...). This combination enables us to turn ON/OFF all kinds of appliances (motors, lights, heaters, boilers, PC...). In case you are having a hard time finding obsolete components, you might want to try the Win-Source.net.
[I'm on HackedGadgets and also on Hack-A-Day :-)]
irswv11
- Controlling two independent appliances via remote controller and wall push-button
- Double-click on the push-button controls second channel B
- Two modes of operation: Toggle and ON/OFF
- Sleep timer in duration of 2 minutes
If used for controlling the lights, this device is connected to existing home wiring installation inside a junction box which is usually located above the light switch. In order to properly connect the device to installation one should follow the schematics provided for that purpose. If connected differently there is a very big chance of some freaky side effects such as burned PIC microcontroller, serious fire and who knows what else.
irswv12
After connecting the device to installation you must program all 5 buttons of the remote control. Here is how to do that:
1. Hold the wall push-button for 11 sec so that the device can enter programming mode. After those 11 sec, LED will start to blink fast and both channels will turn off. Now you have 11 sec to complete the programming sequence:
2. Press the first button on your remote that will turn on first channel (ON - A)
3. Press the second button on your remote that will be used to turn off first channel (OFF - A)
4. Press the third button on your remote that will turn on second channel (ON - B)
5. Press the fourth button on your remote that will be used to turn off second channel (OFF - B)
6. Finally press the fifth button that will be used for activating/deactivating sleep mode (SLEEP)
During programming the LED and channel A will blink to confirm IR code reception. If your remote control does not have all 5 buttons that you can use, you can repeat previous button but that will cancel out some features. For example if your remote has only two buttons [X and Y], and if during programming you press: X X Y Y Y, that means that key X will be used for channel A ON function, and key Y will be used for channel B ON function. In that case you must configure jumper Jp1 for Toggle mode so that you can also turn the channels OFF with the same buttons. If you choose combination X X X X Y, it means that the key X will be used for ON and OFF function of channel A, and key Y will be used to activate/deactivate sleep mode (channel B not used).
Programming notice: If during programming you notice that LED blinks even when you don't press any buttons on your remote control, it is probably because you used TSOP11xx instead of TSOP17xx receiver module. In that case you will probably not be able to program your device properly.
If you are not satisfied with your choice of remote controller buttons you can repeat the learning procedure as many times as you wish.
If you are planning to use your TV's remote controller you should probably choose those teletext buttons: red, green, yellow, blue and some fifth one, to avoid for example, switching channels when operating the device.
irswv13
Appliance controlling
Connected appliances (or just one) can be controlled via the remote controller or the wall push-button.
- Remote controller can work in two modes: Toggle and ON/OFF mode (adjusted with jumper Jp1 in the schematics). Toggle mode is used to control the appliance with only one IR button in T flip-flop fashion: First press of a button turns the channel ON and second button press turns if OFF. ON/OFF mode requires at least two remote buttons, one to turn the channel ON and the other to turn if OFF.
- Wall push-button can control both channels (appliances). Single-click turns OFF all channels and another single-click turns ON those channels that were ON before turning them OFF. Double-click will turn ON all channels if both channels were OFF and if at least one channels was ON it will toggle the second channel. This might seem complicated but I assure you it is not.
Sleep timer can be activated by a bit longer wall push-button press, more than 1.8 sec to be precise, or by pressing the appropriate button on the remote controller. Sleep timer cancellation is accomplished just like the activation. Please note that sleep timer will also be cancelled by turning any channel ON.
irswv14
IR switch in operation: (single channel turn ON and turn OFF)
Download counter: 29,787
Rating: (2.97, votes 6523)
Date: 26-04-2010
Lokalna verzija ove stranice: Dvokanalni IR prekidač v1
753_dual_channel_ir_remote.rar
Bookmark and Share Comments (96)
comment [46]
I can not connect button in the scheme. The device is built into the chandelier; Channel A - fluorescent lamps, the channel B - nightlight. Turn on the chandelier and turns the channel A. Line frequency 50Hz. Controller PIC12F629. Thank you very much!
comment [45]
@ekrivonogov: if you can't connect the button as in schematics, I can recompile the code for you to operate like you described. you just need to tell me what's your mains frequency and what PIC you use in the project.
comment [44]
@ekrivonogov: now I understand your problem. the problem is that you didn't wire everything together according to the schematics I provided. you don't need that switch to turn on/off the chandelier, the TwoChannelIRswitch device will turn it on/off by pressing a button that you need to install! so, remove your switch, make your chandelier be always under power and then add the button to turn on/off manually or use IR remote. can you do that?
comment [43]
Trax: I incorporated a device into a chandelier, to the same set and a nightlight. When I turn the switch on the wall chandelier, the chandelier is turned off. To turn on the light, it further need to enable a remote control. Is it possible to modify the firmware to the device is switched automatically turned on Channel A.
comment [42]
@ekrivonogov: trebas dva puta da pritisnes taster vrlo brzo, i upalices kanal B! mozda je bolje da pises na engleskom jeziku, jer te nisam bas najbolje shvatio sa ovim Google translatorom.
comment [41]
Trax, reci mi, je li moguće napraviti firmware promjenu nakon što je uređaj uključen na kanalu A. Ja ugrađen uređaj luster. kanal uključuje glavno svjetlo, kanal B uključuje noćno svjetlo. Kad sam uključite prekidač na zidu luster svjetlo se isključuje. Da biste omogućili, morate ga uključiti s daljinskim upravljačem. A ako napravite male promjene u firmware, uređaj se može koristiti kao običan luster bez kontrole (uključivanje i isključivanje), kao i od tipkovnice. Do tomuzhe prekidač
comment [40]
da, velik je to posao jer rutina za prijem IR signala mi je takva da ne tretiram "pritisnutu tipku".
comment [39]
Svaka cast, odlican projekt. Imam jedno pitanje: Da li bi bio velik problem preradit firmware da u toggle nacinu rada drzi ukljucen izlaz dokle god je pritisnuta tipka na daljinskom, a kada je pustim da se i izlaz ugasi?
IP: 78.3.230.190
comment [38]
Trebalo bi da radi :)
comment [37]
pozdrav.. zanima me bi li ovaj sklop radio na one male univerzalne upravljače sa par funkcija..??
Comment page: <12345678...>
How much is 9 - 4 = also add letter "a" at the end of your result! Eg.: 7a
