- From Marin on 01-02-2016 at 12:17:31
jeli ko zna na koliko se namješta struja mirovanja,.puno hvala marin
IP: 78.0.104.236
Quote: "Classic transistor amplifier with complementary pair 2SC-2SA at the output, symetrical power supply 2x70V, 250W of power at 4 ohms. In case of offset, use trimpot 3k7 to adjust the current instead of fixed resistors 2k2 and 1k5 (marked with *)."
Author (sent by): cikavaso
Download counter: 9,139
Rating: (2.97, votes 4243)
Date: 23-03-2007
Lokalna verzija ove stranice: Klasično tranzistorsko pojačalo 250W
Tags: . +add your tag
pojačalo sam napravio i izvrsno radi stvarno vrhunski zvuk
IP: 78.0.104.236
Ljudi samo mi objasnite kako da povezem signal na jednom ulazu i jednom izlazu.
IP: 178.223.178.170
Lep pozdrav!
Kad god trebam kakvu semu frka, ma ne kod vas se sve nadje lepo da postojite samo tako
napred.Lep pozdrav.Raso!
dali radi ovo pojaèalo prije nek ga poènem raditi
IP: 193.198.142.9
IP: 193.198.142.9
Evo je iznad ovih komentara, fino pise Fajlovi sheme.
pa gdje je shema
IP: 87.250.109.241
IP: 87.250.109.241
