/Projects/Phone recorder
How many times have you wished that you recorder your recent telephone conversation? I have, many many times. So I finally decided to make this happen by using PC and a piece of hardware (powered from USB) to record audio from phone line to MP3 format. I wanted this thing to work automatically, to start recording when any of phones in house is picked-up (line occupied) and stop recording when all phones are hung-up (line free).
UPDATE: The .RAR file is now updated. So if you have seen the "Output mp3 directory is not valid..." information upon application start, just edit the "opcije.ini" file and adjust the mp3 output directory.
[I'm on Hack-A-Day and also on HackedGadgets :-)]
Update: Source code is available for download [here].
You can download the project files (schematics, source code, windows app) by clicking on the red download button at the end of this article.
P2280260s
How does it work?
The hardware-part consists of:
- audio pickup circuit
- phone line status monitor
- microcontroller to send the phone-line state to PC using USB (serial<->usb)
P2280255s
P2280254s
P2280258s
The software:
- receiving the phone-line state via USB and managing the recording to WAV
- after conversation is finished, converts WAV to MP3 using Lame library
appscreenen
Phone line status monitor circuit
This circuit is basically measuring voltage on the phone-line, which is is above 15 Volts (around 50) when on-hook. When any of the phones is picked-up the voltage drops below 15 Volts. This property is used to detect whether the phone line is in-use or not. The circuit is actually taken from this address and altered a bit.
Audio pickup from telephone line
In this simple part a transformer from an old PC modem i used. There are also 2x1N4148 diodes to limit the output voltage of the transformer to ~0.6V, a resistor and a capacitor. The important part is this capacitor which ensures that phone-line is never occupied by the circuit.
Microcontroller to send data to PC
Microcontroller is checking the phone line status every 0.2 seconds with a help of monitor circuit above. If the optocoupler is "closed" for more than 0.15 seconds it means that the phone line is occupied and it starts to send letter "R" (Rec) to PC application. In other case it sends "S" (Stop). This data is received by the PC where the application starts audio recording (R) or stops (S). Since the microcontroller uses serial communication to send the data, PL-2303 circuit is used to translate those signals to USB. (An entire PCB converter is used in this application, as it can be seen in the picture.) Much better way of doing this is would be with V-USB library (see these simple projects). That way we could use only one Atmel chip instead of these two (PIC + PL-2303).
P2280259s
P2280262s
Download counter: 8,164
Rating: (2.88, votes 4843)
Date: 02-03-2010
Lokalna verzija ove stranice: Snimač telefonskih razgovora
746_phone_recorder.rar
Bookmark and Share Comments (43)
comment [43]
I added link to source code download at the beginning of the page. There is an UPDATE text, look for it.
comment [42]
Nice Project. I need source code of recording application. Does it maintain logs for dialed numbers as well? I need DTMF decoder addition to this. Is that possible? Please provide source code to my email ID. Very useful project indeed. Regards
IP: 47.30.254.0
comment [41]
I will make sure to upload it here when I get home today!
comment [40]
Hi thanks for this project, I interested to see the program files of pic and windows. Can you please send to my email please. Thanks for advanced. bipin.paliyath@gmail.com
IP: 42.111.104.61
comment [39]
Hi That's a very good project. Can you send me your source code in delphi to my email please. Thanks for advanced.
IP: 109.162.220.64
comment [38]
Interested in Windows application. can you please send me the source code on my email. Thanks
IP: 109.161.151.249
comment [37]
Hi, Intersted in windows application. can you please send the source code on my email. Thanks
IP: 109.161.151.249
comment [36]
Yes, you can use Atmel but you need to re-write the firmware.
comment [35]
This is greate project. is it possible to have the source code of recording application. another question can we have more than a line atmel mcu thanks in advance
IP: 109.161.151.249
comment [34]
Hello, Congratulations on the excellent work I'm sure that will this will help in learning electronics for many people. I very happy if you make available to me the code in delphi so I can understand how and made ​​to read the data. grateful
IP: 187.121.93.64
Comment page: 12345>
