- From divljina on 12-11-2012 at 10:43:22
Trax-onja :) hvala . Cestitam i na aktivnosti na youtube-u i ovde :) Pozdrav
FEB4
This project is a very secure entry system for your house or some other protected area.
For entry it uses a PIN code in combination with Java Card™ smart card which performs a challenge-response scheme with triple DES encryption (192 bits long keys). It also has internal real-time clock and all entries through this system are dumped via RS232 port to a PC. It is built around a Keil MCB2130 development board but there is also a full schematics for LPC2138 ARM microcontroller so it can work as a stand-alone system.
It sure seems to provide better protection than those high security locks as we can see here.
© Carlos Cossio
Poštovani,
hteo bih da na mojoj stambenoj zgradi montiram ovakvu bravu za otvaranje ulaznih vrata.
Da li imate u ponudi ovaj modul zajedno sa elektromagnetnom bravom i koliko bi sve to
koštalo.
Hvala unapred.
IP: 93.87.105.83
Ispod slike klikni na link "Izvor" a onda na toj stranici klikni na "Abstract |
Entry".
Da li je moguce nekako postaviti semu ? Da bismo mi koji se slabo u ovo razumemo, da makar
procitamo i naucimo nesto :)
pozdrav
moze li mi netko na mail poslat tiskanu shemu ako ima?
unaprijed zahvaljujem
pozdrav
IP: 84.137.148.205
