/Schematics/Power supply/Triac regulation
Quote: "
This device uses PIC16C54 to control a triac. One push-button has the UP (increase) function, second one has the DOWN function and the third one is for ON-OFF. Button ON will increase the number on LED display from 00 to 99 which represents triac firing in percentages. Triac can power universal load such as light bulbs, motors and similar.
punovalno
BTA40-700 triac is used in this application and it requires cooler. There is also a soft-start/stop function when firing a triac.
46percent
The PCB is 5cm*7cm single sided with SMD parts."
Author (sent by): Drago_Zg
Download counter: 7,110
Rating: (2.91, votes 2579)
Date: 16-09-2009
Lokalna verzija ove stranice: Regulator triaca
687_triac_regulator.rar
Bookmark and Share Comments (7)
hye sir im intrested to do this as my mini project, and im going to change the triac to scr.. can you contact me through my email because i want to ask u something about the coding you used.. thank you soo much..
IP: 210.187.58.166
odlično
imam za diplomski rad da napravim "regulaciju broja okretaja AC motora 1,25kW pomoću tiristora u antiparalelnom spoju" pa me zanima da li mi može netko pomoći ako ima el shemu. i da li bi se ovakav regulator mogao koristiti i u mojem slučaju, samo da se umjesto trijaka koristi tiristor.
IP: 195.29.46.220
Zanimljivo, samo ima jednu manu, a to je nije zero crossing, prva slika lepo prikazuje na osciloskopu da nedostaje taj početni deo sinusoide, tj. ne propušta svu struju. Ovo se može rešiti upotrebom MOC3041 (zero crossing) umesto MOC3021. Uvek treba praktikovati MOC3041 ili sličan zero crossing.
zanima me mozeli se ovaj regulator upotrijebit za primar trafoa kod CO2 aparata
IP: 109.175.99.103
U asemblerskom kodu na forumu su opisane funkcije otpornika.
Planiram da napravim ovaj regulator pa me zanimaju samo varijante sa funkcijskim otpornicima posto nisu detaljno opisane.
Comment page:
