- From pedja089 on 16-09-2009 at 12:59:24
Ma daj ko vodi takve razgovore da iako ga neko cuje da moze sta iskorisiti...
SEP15
There was this document about how it is possible to eavesdrop people using their GSM phones even when they are turned off or not in a call. Some people took this info seriously and decided to neutralize this threat.
Removing battery from a phone is also possible but that disables the phone completely and makes call receiving impossible. The idea is to simply short-circuit the microphone contacts when phone is not in use. So, reed switch in combination with a magnet is used to make the whole thing work.
© Dan
[ Source: Dan ]
Nekada je bitnije odrediti lokaciju na kojoj se nalazi korisnik telefona nego sadržaj
razgovora, pa i o tome treba voditi računa.
To sa vađenjem baterije koliko je sigurno,a vidi se i na ovoj slici mala baterija koja je
zalemljena u telefonu i čuva memoriju,ali i pomaže u "hitnim" situacijama...
IP: 178.77.28.174
Ja koristim jednostavniji način koji ne zahtjeva otvaranje uređaja - stavim ga u gumenu
futrolu koja apsorbira zvukove i tako izolira mikroffon.
