JUL30
Lazy man's USB RFID reader
When we want to connect our RFID reader IC to PC it would be great if it could be powered by and connected to USB port. To avoid building our serial to usb converter we can simply purchase one from a local PC store. In that case we need UART-TTL voltage converter.
RFID reader modules that we can purchase usually work with TTL voltage levels and are powered from 5V. As the serial to usb converter module offers "real" UART port with UART voltages, we also need MAX232 to make it compatible with our 5V reader. This can be done a bit differently but it involves opening and hacking into a serial to usb converter. Read on to see how it can be done to save some money and get an extra IC!
First step would be to pry open the serial to usb converter. This can be done with a scalpel or a saw to get things started. After that we can desolder the existing TTL-UART voltage converter that is usually MAX213. We can skip this step if we don't want this extra IC in our parts box. We also don't need the cable with DB-9 connector anymore, so this can also go away.
MAX213
After that we need to drill some holes for our RFID reader IC. In this case we are using ID-12 125kHz reader.
usbrfid1
Next thing would be to detect the RX pin of usb-serial converter which is in most cases Prolific PL2303.
PL2303pinout
On it's pin 5 we need to connect the "Data out" pin of RFID reader. Besides that we also need to connect the GND pins of both chips together (usually black wire) and we need to supply +5V to our RFID reader from the USB port (usually red wire). Please see schematics below for more information.
usbrfid3
LED can be connected to RFID reader that will blink whenever a card is read. This LED can be used to fill the hole from the cable of DB-9 connector that we have also removed.
schematics
Schematics
usbrfid5
Finished contraption
USB RFID čitač za lijene Bookmark and Share Comments (2)
Imas na www.sparkfun.com
Zanima me gde da nabavim ovaj ID-12 I koja je cena otprilike Hvala
Comment page:
