comment [113]
- From trax on 21-10-2011 at 15:45:30
You can download everything you need by clicking on the RED DOWNLOAD button above the comments.
After GSM call alarm and GSM SMS alarm as two independent modules, I introduce the Tiny GSM alarm system. The main characteristic of this new version is that this device can operate standalone or as a module for existing alarm system. In previous versions we had only the "enable" pin that armed/disarmed the system. Now, aside from that pin we can arm/disarm the system by calling it with our phone.
GSM phone that I used for development of this device is Siemens M35i (19200bps 8-N-1). It must work with other Siemens phones such as: S25, C35(i) (tested and works), A65 and so on (X35, X45)... It is very recommended to modify the phone so that it can be powered and turned on by the device. Also, the SIM PIN code request should be disabled!
Operation
System can be armed and disarmed by calling it from the other phone (who's number is stored in system's gsm's phonebook of course) if it is configured properly with option opt 3, and/or by using the hardware "enable" pin (it is possible to use both at the same time but it might get confusing). If only arming/disarming by call is used, than the "enable" pin must be connected to ground at all times. This can be done with switch who's options is opt 7. In case where calling arm/disarm is not used, than options opt 4 and 5 have other meaning: delayed armed state entering and delayed alarm condition, respectively.
Alarm condition
Status LED
There is a status LED on this device that can be helpful. When system is armed this LED blinks in 1.8 second interval. When disarmed, the LED is turned off. Right after disarming the system this LED will report us of the conditions that device was in during it's last armed state, by blinking:
1. 5 blinks = system was in alarm state, eg. alarm was triggered
3. 2 blinks = there was an error during alarm condition reporting via GSM - it would be wise to check the prepaid credit
4. 1 blink = there was an error during alarm reporting via call
This blinking will be done three times upon disarming and during that time it is not possible to re-arm the system.
Well, we all know how to put a number in phonebook. Even so, it is important to place numbers on a SIM card, not the phone's memory! All phonebook entries must be in locations from 001, 002, 003,... to as many as you like. Don't skip a location! The SMS messages are a bit different as there is no way you can determine what index message is on. So it is wise to delete all messages and create one by one. That way you will know that the first message created is in the first position. Also, if there are for example three messages on a SIM card, deleting the second will brake the queue and reporting will be done by sending only the first message! - This applies to phonebook entries as well.
Backup power
Sensors
The device supports using both types of sensors: with NO (more sensors connected in parallel) and NC (more sensors connected in serial fashion) contacts. The type of sensor used is configured with option opt 6.
Device possibilities and configuration options
This device, as we already know by now, can report alarm condition by using SMS messages or placing a voice call to as many numbers as we like. Besides the remote alerting functionality it has an output MOSFET transistor that can be used to turn on the outside siren and strobe light when alarm activates.
- opt 4) Arming/disarming only by entry at index 1 from SIM phonebook when option 3 is enabled. If option 3 is disabled, than this switch enables/disables the 8.5 seconds countdown timer that delays switching to "armed" state. (DIP switch no. 7)
GSM phone modification
GSM phone is powered from a device itself through 3A LM350 or weaker LM150 voltage regulator. This means that two wires must be extracted from inside the phone: "BAT -" and "BAT +". Some phones will not work like this, so you need to keep the battery connected, just remove battery cells and keep the electronics of the battery.
Video
sensor triggered - alerting initiated
Download counter: 10,177
Rating: (2.94, votes 4457)
Date: 01-09-2009
Thanks I didn't see the download button, one more thing, my teacher ask me your name to write
it down on the documentation of the alarm.
IP: 189.237.64.183
Hi, I would like to make this project for school, is it possible to send me the code or the
component list? my email is csrpazzi@hotmail.com it would be awesome to do this for school.
IP: 140.212.213.40
hello, may send for the source code for the pic16f84a to carubaku@gmail.com
IP: 196.43.133.10
Da ne duzimo raspravu ovde idemo na forum gde cu uskoro okachiti i video zapis kao dokaz da sve
ovo radi savrsheno :) A evo sada prilazem slike na istoj lokaciji pa uporedite :) Uskoro cu da
nabacim redizajn plochice poshto moram josh jedan alarm za prijatelja da radim :)
http://www.elektronika.ba/forum/viewtopic.php?f=9&t=8694
p0z ocekujem vas u temi :)
Mislim na novi plocicu sa DIP komponentama.
Ako neko moze da okaci sliku vece rezolucije gotovog uredjaja koji RADI da bih eventualno
uporedili sa nasim uredjajem koji nam pravi problema i dosta nestabilno rade.Cisto da vizuelno
uporedimo raspored elemenata. Veliko hvala.
Pazi nije ni kod mene bas najsjajnije.Nekad treba telefon da zvoni cak tri puta da bi uredjaj
registrovao da iskljuci alarm a nekad cim prvi put zazvoni.Telefon je s35.
Blago tebi, i to sam probao al' nece :-)
Evo kod mene je proradilo aktiviranje/deaktiviranje pozivom.
Zamenio sam zice od uredjaja do telefona sa debljim i kvalitetnijim i proradilo je.
Bile su mi neke veoma tanke od trakastog kabla.
Neznam kakve ovo veze moze da ima ako je i sa tim losim zicama radio normalno osim komande
deaktiviranja pozivom.
Pozz
