/Projects/Tiny GSM alarm system
After GSM call alarm and GSM SMS alarm as two independent modules, I introduce the Tiny GSM alarm system. The main characteristic of this new version is that this device can operate standalone or as a module for existing alarm system. In previous versions we had only the "enable" pin that armed/disarmed the system. Now, aside from that pin we can arm/disarm the system by calling it with our phone.
front4
back
GSM phone that I used for development of this device is Siemens M35i (19200bps 8-N-1). It must work with other Siemens phones such as: S25, C35(i) (tested and works), A65 and so on (X35, X45)... It is very recommended to modify the phone so that it can be powered and turned on by the device. Also, the SIM PIN code request should be disabled!
Operation
System can be armed and disarmed by calling it from the other phone (who's number is stored in system's gsm's phonebook of course) if it is configured properly with option opt 3, and/or by using the hardware "enable" pin (it is possible to use both at the same time but it might get confusing). If only arming/disarming by call is used, than the "enable" pin must be connected to ground at all times. This can be done with switch who's options is opt 7. In case where calling arm/disarm is not used, than options opt 4 and 5 have other meaning: delayed armed state entering and delayed alarm condition, respectively.
front2
front3
Alarm condition
Status LED
There is a status LED on this device that can be helpful. When system is armed this LED blinks in 1.8 second interval. When disarmed, the LED is turned off. Right after disarming the system this LED will report us of the conditions that device was in during it's last armed state, by blinking:
1. 5 blinks = system was in alarm state, eg. alarm was triggered
3. 2 blinks = there was an error during alarm condition reporting via GSM - it would be wise to check the prepaid credit
4. 1 blink = there was an error during alarm reporting via call
This blinking will be done three times upon disarming and during that time it is not possible to re-arm the system.
Well, we all know how to put a number in phonebook. Even so, it is important to place numbers on a SIM card, not the phone's memory! All phonebook entries must be in locations from 001, 002, 003,... to as many as you like. Don't skip a location! The SMS messages are a bit different as there is no way you can determine what index message is on. So it is wise to delete all messages and create one by one. That way you will know that the first message created is in the first position. Also, if there are for example three messages on a SIM card, deleting the second will brake the queue and reporting will be done by sending only the first message! - This applies to phonebook entries as well.
Backup power
Sensors
The device supports using both types of sensors: with NO (more sensors connected in parallel) and NC (more sensors connected in serial fashion) contacts. The type of sensor used is configured with option opt 6.
senzori
Device possibilities and configuration options
This device, as we already know by now, can report alarm condition by using SMS messages or placing a voice call to as many numbers as we like. Besides the remote alerting functionality it has an output MOSFET transistor that can be used to turn on the outside siren and strobe light when alarm activates.
- opt 4) Arming/disarming only by entry at index 1 from SIM phonebook when option 3 is enabled. If option 3 is disabled, than this switch enables/disables the 8.5 seconds countdown timer that delays switching to "armed" state. (DIP switch no. 7)
DIPswitches
GSM phone modification
GSM phone is powered from a device itself through 3A LM350 or weaker LM150 voltage regulator. This means that two wires must be extracted from inside the phone: "BAT -" and "BAT +". Some phones will not work like this, so you need to keep the battery connected, just remove battery cells and keep the electronics of the battery.
keypad
Video
sensor triggered - alerting initiated
Download counter: 10,182
Rating: (2.94, votes 4552)
Date: 01-09-2009
666_CallAlarmSystem.rar
Bookmark and Share Comments (144)
comment [124]
Verzija sa 16f628 DIP Druže ovo ne šljaka,sve sam proverio 1.Dipove mali milion puta, probao sve žive kombinacije neće 2.Ubacivao i stari hex i novi od 22.11, menjao i kod jednog i kod drugog kod u 0x00 neće 3.Menjao i pic menjao i programator menjao i glupi komp čak neće. 4.Obrnuo fet da stoji kako treba jer na DIP pločici stoji KONTRA, tek tada dobio iole stabilan rad i uključivanje sirene kad se deaktivira. Skidao i sirenu i fet i ceo taj deo neće 5.Prekontrolisao komplet šemu i ploč
comment [123]
Aha znači onda bi bilo ovako ako sam ja dobro shvatio, ako je pin spojen preko dip-a onda je konstantno aktivan i razoruzava se spajanjem ENABLE na masu, tjs vezivanjem na postojeću alarmnu centralu. A ova druga "Naoružavanje/razoružavanje uz pomoć poziva omogućeno/onemogućeno (DIP prekidač br. 6)" to je još neka opcija slična ovoj na dip2 kontaktu ili u nekoj drugoj kombinaciji?
comment [122]
Moras da odlucis kakav nacin naoruzavanja/razoruzavanja hoces da koristis. Ako zauvijek spojis Hardverski ENABLE pin na GND onda mozes koristiti opciju preko poziva. Ako pak ENAB pin budes koristio onda ne mozes koristiti opciju preko poziva.
comment [121]
Zdravo Evo sklapam polako ovaj uređaj, samo me buni upotreba kontakta ENABLE kako je obeležen na šemi. Gde bi on trebao da bude vezan u celom sistemu? Vidim iz teksta da dip br2 stavlja sistem u hardversko "naoružano" stanje, da li to znači da bez obzira na pozivanje alarma sa broja radi deaktivacije, on i dalje ostaje u stanju pripravnosti?
IP: 93.87.140.219
comment [120]
Hex ce biti postavljen gore u RAR fajlu za download veceras.
comment [119]
Trax,ako moze posalji i meni doradjeni hex. Hvala
comment [118]
Hocu predvece, cim dodjem za svoj PC!
comment [117]
Ajde Trax molim te posalji mi na mail pdarko21@yahoo.com ispravljenu verziju, nadam se da ce da resi probleme koje sam ranije imao sa uredjajem.Poz
IP: 109.92.113.160
comment [116]
Ljudi, otkrio sam mali bug u ovom uredjaju. Ako neko hoce, poslacu mu novu verziju HEX-a. Bug je u sustini bio kod ucitavanja podesenja iz EEPROM memorije: vrijeme trajanja sirene, pauza izmedju zvanja alarma itd. Sve je bilo greskom podeseno na maksimum :-) medjutim rijesio sam to ali jos nisam postavio u RAR arhivu.
comment [115]
Hi Cesar, you can write Muris Trax as my name, and include www.elektronika.ba :-)
Comment page: <12345678...>
