comment [133]
- From [edo] on 06-02-2012 at 20:56:37
Ne znam sta da ti kazem...Meni su obe verzije radile sa tim telefonima...Spremam se da napravim
i ovu SMD varijantu za auto :)
After GSM call alarm and GSM SMS alarm as two independent modules, I introduce the Tiny GSM alarm system. The main characteristic of this new version is that this device can operate standalone or as a module for existing alarm system. In previous versions we had only the "enable" pin that armed/disarmed the system. Now, aside from that pin we can arm/disarm the system by calling it with our phone.
GSM phone that I used for development of this device is Siemens M35i (19200bps 8-N-1). It must work with other Siemens phones such as: S25, C35(i) (tested and works), A65 and so on (X35, X45)... It is very recommended to modify the phone so that it can be powered and turned on by the device. Also, the SIM PIN code request should be disabled!
Operation
System can be armed and disarmed by calling it from the other phone (who's number is stored in system's gsm's phonebook of course) if it is configured properly with option opt 3, and/or by using the hardware "enable" pin (it is possible to use both at the same time but it might get confusing). If only arming/disarming by call is used, than the "enable" pin must be connected to ground at all times. This can be done with switch who's options is opt 7. In case where calling arm/disarm is not used, than options opt 4 and 5 have other meaning: delayed armed state entering and delayed alarm condition, respectively.
Alarm condition
Status LED
There is a status LED on this device that can be helpful. When system is armed this LED blinks in 1.8 second interval. When disarmed, the LED is turned off. Right after disarming the system this LED will report us of the conditions that device was in during it's last armed state, by blinking:
1. 5 blinks = system was in alarm state, eg. alarm was triggered
3. 2 blinks = there was an error during alarm condition reporting via GSM - it would be wise to check the prepaid credit
4. 1 blink = there was an error during alarm reporting via call
This blinking will be done three times upon disarming and during that time it is not possible to re-arm the system.
Well, we all know how to put a number in phonebook. Even so, it is important to place numbers on a SIM card, not the phone's memory! All phonebook entries must be in locations from 001, 002, 003,... to as many as you like. Don't skip a location! The SMS messages are a bit different as there is no way you can determine what index message is on. So it is wise to delete all messages and create one by one. That way you will know that the first message created is in the first position. Also, if there are for example three messages on a SIM card, deleting the second will brake the queue and reporting will be done by sending only the first message! - This applies to phonebook entries as well.
Backup power
Sensors
The device supports using both types of sensors: with NO (more sensors connected in parallel) and NC (more sensors connected in serial fashion) contacts. The type of sensor used is configured with option opt 6.
Device possibilities and configuration options
This device, as we already know by now, can report alarm condition by using SMS messages or placing a voice call to as many numbers as we like. Besides the remote alerting functionality it has an output MOSFET transistor that can be used to turn on the outside siren and strobe light when alarm activates.
- opt 4) Arming/disarming only by entry at index 1 from SIM phonebook when option 3 is enabled. If option 3 is disabled, than this switch enables/disables the 8.5 seconds countdown timer that delays switching to "armed" state. (DIP switch no. 7)
GSM phone modification
GSM phone is powered from a device itself through 3A LM350 or weaker LM150 voltage regulator. This means that two wires must be extracted from inside the phone: "BAT -" and "BAT +". Some phones will not work like this, so you need to keep the battery connected, just remove battery cells and keep the electronics of the battery.
Video
sensor triggered - alerting initiated
Download counter: 10,182
Rating: (2.94, votes 4552)
Date: 01-09-2009
Zamolio bih vas ako bi mi mogli samo napisati
koji pinovi su koji, jer mi je jako tesko razumjeti preko scheme (novak sam u tome).
Linije nisu zamenjene sve je na mestu, kao što sam već rekao aktiviranje i deaktiviranje
putem poziva RADI, kao i CALL BACK prilikom deaktivacije ali alarm nikad ne predje u naoružano
stanje.
Ako sad treba da kupim još te telefone e onda baš... kupio na limundu 3komada ako je za volju
dosta je.
Probaj sa starijim modelima C35 ili C45 sa 628 radi :) Da nisi mozda zamenio tx i rx linije?
Update: Probano sa M35i i SF62 stari i novi hex sa 0x00 i 0x01 opcijama i jedan i drugi. NE
RADI. Totalno identični simptomi
Zvanično dižem ruke od 628 verzije dok ne naručim 16f84 pa možda mi se sa njom posreći.
Nesto u hexu verovatno zeza, ne šema. Alarm ima svu komunikaciju sa telefonom, ali nikako ne
pređe u naoružano stanje iako prijavi preko sirene da je naoružan, ne krene dioda da blinka
niti može da se okine preko senzora. Probao sam i varijantu spajanja enable na masu bez dip2
prekidača, ali ni tu ne radi. Uzgred hvala na projektu, verujem da radi ali nešto ostali
imaju muku sa 628 da je osposobe
Plocicu sam proverio, propratio veze sa seme na samom pcb, i jedini problem koji sam imao je
fet za sirenu koji je naopako.
Telefon je s35
Komunikaciju izmedju telefona i alarma imam, radi naoružavanje i razoruzavanje putem poziva,
pozove me kad ga razoružam, ali ni u jednoj situaciji ne pređe u naoružano stanje tjs ne
krene dioda da blinka.
Detektuje da telefon nije prisutan kad mu simuliram iskljucenje dugmetom i opet ga ukljuci kao
sto treba.
Alarm radi DEFINITIVNO, to ti govorim jer sam ga ja projektovao. Sto se tice DIP verzije
plocice - nju nisam testirao, ali provjeri da li je sve OK (ako imas neku sumnju u nju).
Koji telefon ti koristis za ovaj uredjaj?
Okidanje senzora ne pipa, mrtvo, jednom u 40 puta okine pozove i stane, bez obzira na to koji
je hex ili telefon zakačen.
Opet da napomenem da su svi dipovi na svom mestu i sve je podešeno.
Najbolje neka nam neko kaže da se ne zezamo da pravimo ovo jer ne valja to i to i radi samo sa
tim i tim, da završimo priču.
Jer koliko vidim dip verzija radi samo kod dvojice ljudi a kod ostalih jok.
i pločicu i elemente sve je ok i ispravno i neće
Alarm se ponaša ovako, zakačim ga na napajanje, upali diodu jednom pa drugi put i to je to
nema kratkog (3 puta) blinkanja kao da je naoružan. Pozovem telefonom alarm se deaktivira
čujem 3 kratka tona iz sirene, kada je dip na call back položaju onda me pozove. Pozovoem
opet čujem jedan kratak ton iz sirene i to je to opet nema blinkanja nakon ponovnog
aktiviranja.
