/Projects/Tiny GSM alarm system
After GSM call alarm and GSM SMS alarm as two independent modules, I introduce the Tiny GSM alarm system. The main characteristic of this new version is that this device can operate standalone or as a module for existing alarm system. In previous versions we had only the "enable" pin that armed/disarmed the system. Now, aside from that pin we can arm/disarm the system by calling it with our phone.
front4
back
GSM phone that I used for development of this device is Siemens M35i (19200bps 8-N-1). It must work with other Siemens phones such as: S25, C35(i) (tested and works), A65 and so on (X35, X45)... It is very recommended to modify the phone so that it can be powered and turned on by the device. Also, the SIM PIN code request should be disabled!
Operation
System can be armed and disarmed by calling it from the other phone (who's number is stored in system's gsm's phonebook of course) if it is configured properly with option opt 3, and/or by using the hardware "enable" pin (it is possible to use both at the same time but it might get confusing). If only arming/disarming by call is used, than the "enable" pin must be connected to ground at all times. This can be done with switch who's options is opt 7. In case where calling arm/disarm is not used, than options opt 4 and 5 have other meaning: delayed armed state entering and delayed alarm condition, respectively.
front2
front3
Alarm condition
Status LED
There is a status LED on this device that can be helpful. When system is armed this LED blinks in 1.8 second interval. When disarmed, the LED is turned off. Right after disarming the system this LED will report us of the conditions that device was in during it's last armed state, by blinking:
1. 5 blinks = system was in alarm state, eg. alarm was triggered
3. 2 blinks = there was an error during alarm condition reporting via GSM - it would be wise to check the prepaid credit
4. 1 blink = there was an error during alarm reporting via call
This blinking will be done three times upon disarming and during that time it is not possible to re-arm the system.
Well, we all know how to put a number in phonebook. Even so, it is important to place numbers on a SIM card, not the phone's memory! All phonebook entries must be in locations from 001, 002, 003,... to as many as you like. Don't skip a location! The SMS messages are a bit different as there is no way you can determine what index message is on. So it is wise to delete all messages and create one by one. That way you will know that the first message created is in the first position. Also, if there are for example three messages on a SIM card, deleting the second will brake the queue and reporting will be done by sending only the first message! - This applies to phonebook entries as well.
Backup power
Sensors
The device supports using both types of sensors: with NO (more sensors connected in parallel) and NC (more sensors connected in serial fashion) contacts. The type of sensor used is configured with option opt 6.
senzori
Device possibilities and configuration options
This device, as we already know by now, can report alarm condition by using SMS messages or placing a voice call to as many numbers as we like. Besides the remote alerting functionality it has an output MOSFET transistor that can be used to turn on the outside siren and strobe light when alarm activates.
- opt 4) Arming/disarming only by entry at index 1 from SIM phonebook when option 3 is enabled. If option 3 is disabled, than this switch enables/disables the 8.5 seconds countdown timer that delays switching to "armed" state. (DIP switch no. 7)
DIPswitches
GSM phone modification
GSM phone is powered from a device itself through 3A LM350 or weaker LM150 voltage regulator. This means that two wires must be extracted from inside the phone: "BAT -" and "BAT +". Some phones will not work like this, so you need to keep the battery connected, just remove battery cells and keep the electronics of the battery.
keypad
Video
sensor triggered - alerting initiated
Download counter: 10,182
Rating: (2.94, votes 4552)
Date: 01-09-2009
666_CallAlarmSystem.rar
Bookmark and Share Comments (144)
comment [14]
Ne moze C25.
Zanima me dali je neko probao da uradi ovaj projekat sa telefonom siemens C25 .Ja sam probao sa dva telefona ali nece da radi ni jedan
Zalemi zice na PIC i spojim na programator, ako nemas odgovarajuci prelaz, a ocigledno nemas :-) To ti je jedini nacin. Ili nakon sto ga zalemis na plocicu, onda zalemi zice na odgovarajuca mjesta na plocici i to je to. Trebaju ti: VCC, GND, MCLR, RB6 i RB7. Valjda nisam nista zaboravio...
Mozda je pitanje smesno za nekog ko je vec imao iskustva sa PICovima, ali ... Kako uploadovati hex fajlove na SMD kontroler? Hvala!
IP: 188.2.185.95
Za koliko bi para meni mogao sloziti jedan takav uredjaj reci cjenu pa da vidimo il jos bolje posalji mi sms na +38761604236
IP: 213.196.81.94
Testirano i sa: Siemens A75, MC60 i S65!
Spoji ga na PC preko MAX232 i probaj u HyperTerminalu da li se odaziva na AT komande. Ako bude - moze.
Da li ovo radi sa A35? Unapred hvala na odgovoru. Pozdrav, Sasa
IP: 94.189.162.49
hvala
Ista je plocica (za sad), ali sa vise RAM-a i FLASH-a mogu nadograditi jos toga... Radi sa F628, samo sam inicijalizovao komparatore i gluposti koje mi ne trebaju, kao i pomjerio malo RAM i to je to. Koristi se HW interrupt na RB0 za senzor, a UART - i to se moze nastimati, samo tad treba mijenjati pinout, znaci to u drugoj verziji samo za F628. Planiram napraviti pracenje vozila na toj F628, u F84 mi fali RAM-a za procesiranje SMS poruke...
Comment page: <...9101112131415>
