comment [43]
- From Rale on 23-08-2010 at 10:26:45
Da li bi mogao tko programirat pic jer nemam aparaturu?
IP: 93.137.46.56
After GSM call alarm and GSM SMS alarm as two independent modules, I introduce the Tiny GSM alarm system. The main characteristic of this new version is that this device can operate standalone or as a module for existing alarm system. In previous versions we had only the "enable" pin that armed/disarmed the system. Now, aside from that pin we can arm/disarm the system by calling it with our phone.
GSM phone that I used for development of this device is Siemens M35i (19200bps 8-N-1). It must work with other Siemens phones such as: S25, C35(i) (tested and works), A65 and so on (X35, X45)... It is very recommended to modify the phone so that it can be powered and turned on by the device. Also, the SIM PIN code request should be disabled!
Operation
System can be armed and disarmed by calling it from the other phone (who's number is stored in system's gsm's phonebook of course) if it is configured properly with option opt 3, and/or by using the hardware "enable" pin (it is possible to use both at the same time but it might get confusing). If only arming/disarming by call is used, than the "enable" pin must be connected to ground at all times. This can be done with switch who's options is opt 7. In case where calling arm/disarm is not used, than options opt 4 and 5 have other meaning: delayed armed state entering and delayed alarm condition, respectively.
Alarm condition
Status LED
There is a status LED on this device that can be helpful. When system is armed this LED blinks in 1.8 second interval. When disarmed, the LED is turned off. Right after disarming the system this LED will report us of the conditions that device was in during it's last armed state, by blinking:
1. 5 blinks = system was in alarm state, eg. alarm was triggered
3. 2 blinks = there was an error during alarm condition reporting via GSM - it would be wise to check the prepaid credit
4. 1 blink = there was an error during alarm reporting via call
This blinking will be done three times upon disarming and during that time it is not possible to re-arm the system.
Well, we all know how to put a number in phonebook. Even so, it is important to place numbers on a SIM card, not the phone's memory! All phonebook entries must be in locations from 001, 002, 003,... to as many as you like. Don't skip a location! The SMS messages are a bit different as there is no way you can determine what index message is on. So it is wise to delete all messages and create one by one. That way you will know that the first message created is in the first position. Also, if there are for example three messages on a SIM card, deleting the second will brake the queue and reporting will be done by sending only the first message! - This applies to phonebook entries as well.
Backup power
Sensors
The device supports using both types of sensors: with NO (more sensors connected in parallel) and NC (more sensors connected in serial fashion) contacts. The type of sensor used is configured with option opt 6.
Device possibilities and configuration options
This device, as we already know by now, can report alarm condition by using SMS messages or placing a voice call to as many numbers as we like. Besides the remote alerting functionality it has an output MOSFET transistor that can be used to turn on the outside siren and strobe light when alarm activates.
- opt 4) Arming/disarming only by entry at index 1 from SIM phonebook when option 3 is enabled. If option 3 is disabled, than this switch enables/disables the 8.5 seconds countdown timer that delays switching to "armed" state. (DIP switch no. 7)
GSM phone modification
GSM phone is powered from a device itself through 3A LM350 or weaker LM150 voltage regulator. This means that two wires must be extracted from inside the phone: "BAT -" and "BAT +". Some phones will not work like this, so you need to keep the battery connected, just remove battery cells and keep the electronics of the battery.
Video
sensor triggered - alerting initiated
Download counter: 10,182
Rating: (2.94, votes 4552)
Date: 01-09-2009
Zavisi rale odakle si...Obrati se na forumu ili pravi svoj programator ako se planirash baviti
elektronikom. Preporucujem AllPic Prog koji ima ICSP konektor za SMD tip PIC-a pa se zice zamo
zaleme na vodove do PIC-a a i ima konektore za DIP verziju PIC-a. Potrazi po forumu ima
sindjina verzija AllPic-a sa PCB-om, a i ovaj alarm je odradjen i u SMD i u DIP varijanti...
IP: 93.137.46.56
Hi Trax, it is not possible for you to send me your program .asm? because It's difficult for me
to find a siemens phone in my town and I need to try other gsm; so, I want modify some
parameters in your program...baude rate, command AT...; if you want. Thanks
Kada ucitas HEX u programator, odes u prozor sa EEPROM podacima. Odes na zadnju lokaciju i tu
upisi 1 (0x01), i tek onda pritisni "BURN" ili "PROGRAM" tipku da
isprogramiras PIC.
Trax da li na M35i treba biti 0x00 ili 0x01 tj. neznam gdije se treba promjeniti.
Hvala.
Zasada je testirano sa Siemens c35 i m35...
Trax.
Napravio sam uređaj ali ništa se ne događa da li može raditi sa C60.
Hvala
Unfortunately not yet :-( Maybe someone will build one for you, try asking help on forums!
Is there any shop selling the system plug & play ? I am a moron in electronics and I need
to purchase one to test, then many of them.
Please send me an e-mail at :
philippegiboulot at yahoo dot com
thank you
IP: 89.81.201.63
pa vezano za sirenu, ako imaš pravu alarmnu smonapajajuču zidnu sirenu, i to moze raditi, jer
ona počne svirati kad nestane napajanje ili kad okineš io pinove, ali kolko se sječam ti i/o
pinovi su držali negdje do +5v jedino napajanje takve sirene je iz njenog internog akumulatora
do 20-tak sati kasnije treba puniti, ali alar-automatika ri ti je imala neku svid seriju
samonapajajučih vanjskih sirena s solarnim panelićem u sebi a za okidanje si imao malu
wireles pločicu extra u paketu, i sve je koš
