JUL3
Interfacing LED matrix to Arduino
Connecting many LEDs on a microcontroller can sometimes be a real hassle. Here you will see how easy it is to connect 80 LEDs to only 8+2 microcontroller pins.
In this project, decimal counter chip CD4017 is used which is controlled with only two pins: clock and reset. Clock pin will "shift" the ON state of outputs from 1 through 10, while reset pin resets state to first output. This counter is used to address 10 rows on a display, while 8 columns (10x8) are controlled directly from a microcontroller which in this case is Arduino. Outputs of decimal counter are amplified with NPN transistors as seen in the schematics. Source code is available for download on project page.
© Syst3mX
[ Source: Syst3mX ]
- Make arduino image scanner/sequencer (06-11-2009) [@News]
- DIY LED chandelier (05-01-2009) [@News]
- Sound controlled light show (27-02-2005) [@Schematics/Optics]
- LIDAR gun tester with Arduino (16-11-2009) [@News]
- Arduino Fortune Teller (16-01-2009) [@News]
- Crystal controlled FM bug (03-12-2006) [@Schematics/Bugs]
- LED monitor for phone line (20-02-2004) [@Schematics/Telephone circuits]
- LED blinker on 1.5V v2 (31-03-2004) [@Schematics/Optics]
- WiFi enabled Nixie clock using ESP8266 (21-09-2015) [@News]
- LED VU-meter (07-03-2004) [@Schematics/Optics]
