- From trax on 27-03-2011 at 20:31:41
idi na ebay.com i trazi: UV LED 5mm
APR20
Here is a very nicely built double sided PCB UV exposure box made out of wood, glass and UV LEDs. Exposure time is about 2-3 minutes, but that depends on photo lacquer thickness and age.
There are two panels with 84 UV LEDs on each, that is 168 UV LEDs in total. One panel draws 700mA from a 12V source. It is recommended that 2000mcd LEDs are used with peak wavelength of 400nm. All diodes are soldered on a veroboard which was probably a great advantage since minimum of 336 holes had to be drilled.
© djhamer
[ Source: djhamer ]
da li su ove dovoljno jake?
http://cgi.ebay.com/100-pcs-5mm-UV-LED-Ultra-Bright-200-pcs-Free-Resistor-/220756414972?pt=LH_D
efaultDomain_0&hash=item33661b91fc#ht_4777wt_1141
kako da preračunam koliko komada mi treba jer trebalo bi mi 36W snage...?
IP: 89.17.28.224
zanima me koja je cijena tih UV LE dioda?
IP: 89.17.22.153
zanima me dali netko moze napraviti plocice po ovom projektu dovoljno veliku da se mogu
osvjetljavati plocice do formata A4 i po kojoj cijeni.
IP: 95.178.181.24
