Da li neko zna semu za pravljenje solarne ploce...
Ako zan neka je postavi...
MAR24
You probably know about a battery that can be built by using a lemon (or onion, potato, grape...) and two electrodes of a different type of metals. With that we can only get around 0.5 to 1V.
This battery is made out of 4 cells, weights just 0.85g and can supply power for a bright LED for 60 minutes. The best part of it is that you don't need to carry a lemon around with you. You only need 4 drops of lemon juice and you got your self a 3.5V 35mAh battery.
To make this battery you will need a zinc wire, some copper wire and a paper tissue that will act as a lemon juice storage compartment.
© madaeon
[ Source: madaeon ]
