MAR21
VCR cassette clock
Although you probably don't have a VCR anymore, you must have a few VHS cassettes laying around somewhere. By using one VHS tape, LED diode and an old quartz clock you can make pretty unusual clock.
What must be taken care of is that the numbering should be anticlockwise since the transparent disc holding the numbers is being rotated from left to right. The numbering of hours is accomplished by etching or engraving the transparent disc so it can catch light from an LED below. Engraving could be done by using hot soldering iron and steady hands.
© lemonie
[ Source: lemonie ]
- Warm Tube Clock v1 - User pictures (06-05-2011) [@News]
- Electromechanical Nixie Clock (09-07-2010) [@News]
- Warm Tube Clock - Nixie Clock with 4 tubes (27-11-2010) [@News]
- Master Clock driver for antique slave clocks (05-05-2016) [@Schematics/Everything else]
- Digital clock/calendar/thermometer (10-08-2010) [@News]
- Low frequency clock signal source (23-02-2004) [@Schematics/Everything else]
- IN-8 single nixie tube clock published (26-08-2009) [@News]
- POV Propeller Clock Build (23-08-2010) [@News]
- LED clock with DCF77 time sync (27-12-2008) [@News]
- Warm Tube Clock v2 - Nixie Clock with 4 tubes (03-06-2011) [@News]
