- From trax on 12-02-2009 at 04:22:30
Izvadio sam ga iz onog PIR senzora sa reflektorom.
FEB7
This is a very simple IR light dimmer that you will wish to have sooner or later, especially those who are lazy enough to get up and turn off the lights. There are two versions of PCB for two sizes of capacitors: 32.5 x 26.5mm and 28.5 x 27mm.
Features of current beta version of firmware: soft start, soft down, learning IR codes from RC5 and NEC remotes, dimming in 10 levels by using only IR remote, previous dimm-level remembering when operating with remote, sleep timer in duration of 1.6min for 60Hz version and 2min for 50Hz version, ON/OFF control with wall pushbutton.
