Download counter: 55,395
Rating: (3.00, votes 8291)
comment [347]
i will do as you advice. thank you so much master trax. more power to you!!!
comment [346]
You will have problems with other triacs, so there is really no direct replacement. If you want, you can use MOC3023 plus any other triac you can find and then it should work.
comment [345]
its almost finish! but i have no luck finding tic 206 or tic 216. can you recommend other possible triacs that i can use for 220v/60hz? please help me master trax.
IP: 49.144.158.133
comment [344]
ill start buying components tomorrow.thank you so much master trax!
IP: 49.144.158.133
comment [343]
Yes, you can use those capacitors...
comment [342]
is is ok to use MKP or MKS type capacitor for C1 coz i cant find MKT type. im just starting to build this project. this project is awesome! thank you for being soooooooo intelligent and generous master trax.
IP: 49.144.158.133
comment [341]
Dom je resio problem dimera koji mu daje 130v tako sto je imao srecu da nadje tic206m koji moze da se ukljucuje preko 820 oma na gejtu. Ja sa skoro napravio ovaj dimer i isto mi se ponasao kao kod Doma i verovatno kod vecine koji su ga pravili tacno po shemi.Otpornik od 820 na gejtu je dobar za savsen tic206m ali za malo losiji mora se smanjiti na 510 oma koliko sam ja stavio i dimer mi savseno radi.
IP: 178.223.237.192
comment [340]
Sad vidim ogg za led... I ne razumem ga. U celoj toj prici ja nemam trafo, led su na 220V, kao halogene. verovatno se napajaju nekom rc vezom... znaci nije trafo...
IP: 89.216.193.140
comment [339]
Kao sto sam i mislio, cela serija trijaka je losa.. sreca pa sam samo 3 komada uzeo. Stavio 206m iz druge serije, raadi savrseno ;)
IP: 89.216.193.140
comment [338]
Mozes dimovati LED-ice, ali tako sto ces trafo da stavis prije dimmera. Znaci i dimmer trebas napajati poslije trafoa! Tako ces morati prepraviti i one C1 R1 komponente (smanjiti) da mogu napajati dimmer.
Comment page: <12345678...>
