Download counter: 55,348
Rating: (3.00, votes 8215)
comment [47]
By the Way Trax...Do you know any circuit to do just the "Soft Start/Down" part ? I love this effect and would like to add it to all my house lights. I want to put Your digital Dimmer on my living lights and soft/start/down on all the others. lol. :) Is there any simple way to do it ? BTW : Now i've realised you're the Author of the Article/Circuit. Thanks to be so kind sharing it and helping me out. :)
IP: 187.9.44.150
comment [46]
Thanks again Trax. Hmm. Because of my first problem i've Re-writen the PIC many times, and Erase-it and Re-write, and Erase-it, so on... So, the calibration value is gone forever for that Pic ? Do i need to trow it on the trash and get another one in place in order to read the right calib ? :( Anyway, i will build the circuit now and do my tests. ;)
IP: 187.9.44.150
comment [45]
I guess you should do a READ PIC first, that way the calibration value will be read and you will know it for future. That calibration value is very important because it is used for time measurement used by IR receiving routine, so you shouldn't rewrite it. Yes, you better use the default calibration value from the mentioned location.
comment [44]
Hi. The CP option works. No errors now. Thanks Trax ! But i have another question...When starts the write process the Picburner software asks that : No "Oscillator Calibration Value" found. Do you want to use value from file (3FFFh) instead? --- What could be the right answer for that ? :) Tnx again. I will try yes and no anyway. ;)
IP: 189.62.107.252
comment [43]
Thanks a LOT Trax. I will teste using this option you've mentioned. Sorry. The wrote the Pic name wrong. :( I am using Exactly the 12F629 and burning with a Serial PicBurner. Trying to burn the 60Hz version of it. (I am from Brazil).:) Wish me luck ! Iam dreaming to build this unit sucessfully. It will help me a lot on my home project ! Thanks again to the autor and Trax. :)
IP: 187.9.44.150
comment [42]
The HEX file is OK. Turn off the "CP" (Code protect) checkbox before programming and it will verify! And it is not 626, it is PIC16F629 or F675.
comment [41]
Hi. I have problems burning the 626 HEX for the 60Hz version...It keeps me bugging with a messagem about 0000h empty, something like that... Is this a problem with the HEX file ? :( Sorry about my english. And Thnks for ANY help !
IP: 187.9.44.150
comment [40]
Crkao ti je PIC, to ti garantujem. Pored toga, probaj naci TIC206 jer sa njim radi bolje. Znaci, probaj novi PIC i pazi kako spajas, radi se o visokom naponu!
comment [39]
Trax. Da, stavio sam TIC216 i 1k u gate (nisam našao 820E SMD). Ima još nešto, kod prvog uključivanja su mi bile zamijenjene diode, znači: na mjesto zenner diode je bila 1N4007, a na mjestu 1N4007 je bila zenner dioda 5,6V. Budući da uređaj nije radio potražio sam grešku i vidio da su diode zamijenjene. Zamijenio sam diode (koje su ostale ispravne) i opet ništa. Tek nakon toga sam išao mjeriti napajanje PIC-a. Bilo je 5V. Sad razmišljam da li je PIC mogao, na taj način, dobiti veće napajanje,
comment [38]
Da, morao bi raditi i samo sa tipkom. Kakav si triac stavio? Stavi TIC206 jer sa TIC216 mnogi imaju problema!!!
Comment page: <...33343536373839>
