Download counter: 55,370
Rating: (3.00, votes 8238)
comment [57]
Any progress on dimmer project? :)
comment [56]
Ok. I am a bit frustated now... I've dedicated all my saturday and part of sunday, to build my PCB, buy all the pieces, burned the PIC correctly, and assembly everything, and put on the AC (110v/60Hz). Simply nothing happened. :( Not even exploded. (lol). Nothing get warm, the Bulb don't started up, the led don't blink, nothing. Very strange. I will replace the PIC now, and re-check everything...Wish me luck. :)
IP: 189.62.107.252
comment [55]
I saw the PCD pictures of your circuit mouted, and saw that the correct is the RESISTOR R5 directly to the PIC pin2. thx
IP: 189.62.107.252
comment [54]
Hi Trax ! I am assembling the circuit parts right now and soldering... I have another doubt... Look at the PIC Pin 2. You have a LED directly to it on the Schematics, but on the PCB there's the "R5" Resistor on the PIN2 and then on the LEDa (Anode). Wich one is the right ?
IP: 189.62.107.252
comment [53]
Yes, LEDa = anode, LEDk = cathode :)
comment [52]
Hmmm. Maybe LEDk is "LED CATODE"(Negative) ? and LEDa relative to LED ANODE (Positve) ? Hmmm.
IP: 187.9.44.150
comment [51]
Trax. I am rebuilding the PCD layout using the Sprint-Layout. Adjusting it to use Regular Resistors (Non-SMD), so another doubt poped-out in my mind... There's "LEDa" and "LEDk" indications on the board. But these points shows just 1 pin (drill)... And i can't see Leds on your Photos of the board... Can you help me on that ? Sorry to bug you everyday with that questions.And tnx in Advance for your help.:)
IP: 187.9.44.150
comment [50]
Great! Here are the PCBs with large components: http://www.elektronika.ba/forum/viewtopic.php?f=9&t=6598
comment [49]
Trax. Now everything looks ok. :) I've read another brandNew 629, and took the Calib.Value, merged it on your code,and burned it back with your Hex using CP checkbox unchecked. Sucessful. :) Thx again. Now i am going to build the PCB... I will need to change the layout a bit cause your are using some SMD Resistors, and they are not to easy to find here... I will have to use ordinary resistors with the same specs.
IP: 189.62.107.252
comment [48]
Hi! Well, you don't have to throw it in the trash. There is a way to figure out that calibration value, but you must google for it. Anyway, for the dimmer you probably will have to use another one. I am not sure what you want to do with your living rooms but there has to be the soft up/down circuit for you *somewhere* on the web :)
Comment page: <...33343536373839>
