Download counter: 55,370
Rating: (3.00, votes 8238)
comment [137]
Ma mozes, prodaj... Samo nemoj se obogatiti :-)
comment [136]
Mogu li ja koji komad prodati. Mislim na autorska prava. pozzz
comment [135]
Yes, it can work on 220V/60Hz. Use 220V schematics and 60Hz HEX file.
comment [134]
can i use this on 230v/60hz...thanks...
IP: 125.60.209.68
comment [133]
Kondenzator od 0,47uF/250V imate u svakom PC napajanju u ulaznom delu...
comment [132]
Radi li ti ikako?? Odakle si?
IP: 89.111.215.162
comment [131]
Postovani Dali je neko uradio ovaj dimmer i kako radi? Ja sam ga napravio i nece, verojatno je greska u programiranju 12F629, prodaje li neko isprogramirane 12F629 i koja je cjena? Unapred zahvaljujem
IP: 77.28.221.193
comment [130]
Finally it Works FLAWLESS !!!! Man you are my hero ! : ) lol. I've commented here a ton of months ago, sayint that my trial was failed but the error was mine. I've soldered the IR receiver WRONG !! :) I am in Brazil and builded the 60Hz board. It worked LIKE A CHARM! I just can't see the "soft start/down... I don't know how to activate it... :( I love the soft start/down effect, but i can't see it's working here... :( My next Challenge was to try to control 6 groups of lights (20 hallog
IP: 187.38.210.167
comment [129]
Pa zavisi u kojoj radnji trazis. To iskreno, neznam ni ja, ali ja sam kupio sve kondenzatore od 0.47 uF i onda sam probao svaki, i ovaj odgovara. http://www.kelco.rs/katalog/komponente.php?IDgroupweb=610 onaj gde pise MKPX2 470N (nema od 0.39 uF, ali radi i sa 0.47 )
comment [128]
U kojoj kategoriji da trazim ovaj kondenzator od 0.39uF na slici vidim da je bas veliki. Inace pocetnik sam u ovome i ne znam sve komponente...
IP: 93.86.188.15
Comment page: <...2526272829303132...>
