Download counter: 55,414
Rating: (3.00, votes 8326)
comment [207]
Juupiiii, tako sam i ja mislio da ide, ali nisam bio 100\% siguran...Ma bitno je da sam najzad poceo da ih shvatam...Vrlo pomno pratim nastavu od pedja089 i dacu sve od sebe da najzad sklavirim te mikrokontrolere i njihove programe....Ma ne pitaj, imao sam neki luster gde idu neke boze me sacuvaj sijalice, a crkavaju bar jednom mesecno, al je zato fensi luster...:-)
comment [206]
@evilmax: i jos nesto, pa sto mijenjas te sijalice tako cesto???
comment [205]
@evilmax: mislim da mozes staviti reset tipku na taj pin, ali onda moras staviti i otpornik na taj pin koji ce biti spojen na +Vcc. kada to uradis, moras re-programirati PIC i prilikom programiranja izabrati MCLRE(on) da omogucis MCLR pin.
comment [204]
Interesuje me da li mogu nekako da dodam jedan maleni taster za restart programa ili celog mcu-a, jer mi se desava da prilikom zamene sijalice uredjaj se zaglupi i ne reaguje dok mu ne otkacim napajanje a to nije bas ni tako zgodno jer moram svaki put da caprkam po instalaciji, posto vidim da je nozica 4 ostala neiskoriscena,a na toj nozici je i mclr....Al ja sam jos truli pocetnik pa ne znam moze li tako nesto......Pozdrav svima...
comment [203]
trax, R1, C1 l'adresse which can approximate values?
IP: 201.68.253.9
comment [202]
@ebicempre: yes, you can experiment with C1 and R1 and also with R2! No, I don't think that MOC3010 will work because it requires too much current (15mA), where MOC3023 requires only 5mA! You can use MOC3023 on PIC's PIN 7.
comment [201]
Thank trax, I use R2 (470R) without problem? to replace R1, C1 can use that approximate values? thanks! MOC3023 else can I put in 3010 or output pin 7 of the pic? to put in another type of Triac?
IP: 201.68.253.9
comment [200]
@Zarlanga: this is basic triac control, see internet for tutorials on triacs with microcontrollers!
comment [199]
@ebicempre: I am glad you made it work! No, you can't control fans because they are "inductive load".
comment [198]
@npn: 1. moglo bi, ali zahtjeva raznorazne izmjene u kodu a za to trenutno nemam vremena :) 2. snagu TIC-a provjeri u njegovom datasheet, skini sa interneta...
Comment page: <...1718192021222324...>
How much is 9 * 7 = also add letter "a" at the end of your result! Eg.: 7a
