Download counter: 55,395
Rating: (3.00, votes 8292)
comment [277]
Cuti, skoro pa sam i ja pobudalio :)
comment [276]
Pretpostavljam da ces dobiti odgovor u vidu "Ima literature, zove se Google"....! Sto inace i jeste sama srz odgovora... Svaka ti cast Trax za nemilosrdno ponavljanje istih odgovora ljudima koje apsolutno mrzi da citaju prosle komentare...! Ti prijatelju imas zivce ko sajle na kalifornijskom "Golden Gate" mostu.....! Ili si pak na nekim lekovima, sto bas i ne verujem....;-)
comment [275]
pozdrav,da li netko ima literaturu koja opisuje rad ovog sklopa ???
comment [274]
thanks for quick response. Im looking for some dimmer witch can dim CFL and have IR remote.
IP: 95.102.107.127
comment [273]
It will work only on resistive loads, it will not work on Neons fluorescent lamps. LEDs will work only if they don't have a transformer in their electronics. You can see my other project IR Light Switch v1 - it will work on fluorescent but no dimming function.
comment [272]
Hi there Could you please advice if this dimmer is compatible with fluorescent or LED lamps?
IP: 95.102.107.127
comment [271]
Mislim da nece moci taj BTA umjesto TIC-a. BTA trazi nesto vecu struju na GATE-u koju PIC nije u mogucnosti da da u ovom sklopu. Mozes probati... pa ako ne bude radilo trazi TIC.
comment [270]
moze li BTA 06-600B umjesto TIC206?
comment [269]
Moze i taj kondenzator, trebalo bi da radi bez problema.
comment [268]
može li se za 220V/50 Hz staviti C1 0,47uF ??
