Download counter: 55,395
Rating: (3.00, votes 8292)
comment [297]
It works!!! It works!!!!!! it works!!!! sorry for my exclamation lol but i m very happy... finally it works! damn Tsop distribution pins!!!! Thnks again Trax and most of all four your patience! Jorge from Argentina...(220v-50Hz)
IP: 190.16.97.116
comment [296]
Thank You Trax, the problem was te Tsop pins, now its ok, in the pic I have 5v between pin1 and pin8... Anyway there is a program problem... when I push botton 11 sec, light turns on and led blinks for some seconds... but cant set it with the remote control... i figure there s a frecuency problem with the IR maybe...
IP: 190.16.97.116
comment [295]
You should measure voltage between pins 1 (Vcc) and 8 (GND) and there you should see around 5V! If you don't have around 5V there then you have some problem with wiring or faulty components. You can test that part without the PIC in the circuit. After you get 5V between 1 and 8 pins then you can plug in your PIC and go to the next step.
comment [294]
Sorry in my last post I meant between pin1 and pin8 (live)
IP: 190.16.85.208
comment [293]
Thank You Trax for your great project!!! I finallly get the smd components...not working, but the good new is nothing has exploded :) I ve check Pic vcc between pin number1 and Neutral and there is 2v... is it right??? I dont think so... Thanks in advance and for you patience!!!
IP: 190.16.85.208
comment [292]
The SMD parts are 0603 :-)
comment [291]
Thanks for sharing this project!!! are you using 0805 smd resistors?? or 0603??? thnks!!!
IP: 190.16.85.208
comment [290]
:)) no i know that mode, it s more weak, and if it s activated after 2-3 min. the lamp will go off. :) ok i dont have chance to do circuits again, so i plan to use more higher watt lamp. does it supply my need? will i get more brightness on 10th level.? thanx
IP: 91.198.49.2
comment [289]
I think he activated "sleep mode" which sets brightness to 60\%.
IP: 89.146.171.82
comment [288]
ok thanx for the info, so i plan to use higher watt halogen than the current one, so it suplies my need. by the way great project, if u think cost and effects :)
IP: 91.198.49.2
