Broj download-a: 55,389
Ocjena: (3.00, glasova 8269)
komentar [357]
You can download schematics by clicking on the RED DOWNLOAD button just above these comments...
komentar [356]
Can you just post a scheme up again?? or you can send it to me in PM!! Thank you.
komentar [355]
There is a transformerless power supply device in the circuit and it regulates 220V to 5V. If you are not experienced with high voltages, please do not build this circuit as it is not safe for beginners. Even with this 5V power supply, you CAN NOT touch anything while it is powered.
komentar [354]
I have a small question now I Know that pic work with 5V for vdd so I see that u connect it directly to AC volt so how it works ?
IP: 41.238.111.190
komentar [353]
oops..it didnt show any chars in between. it should be. pic pin 7---470R---moc3023 pin 1. moc pin 2---ground. moc pin 4--triac 3(gate). moc pin 6---390R---triac pin2.
komentar [352]
to toose: im trying to understand comments using translator and its not accurate. are you asking how moc3023 was connected? if so, i took out r2. then connected pic pin 7470Rmoc3023 pin 1. moc pin 2ground. moc pin 4triac 3(gate). moc pin 6390Rtriac pin2. and as Master Trax said, we can now use any triac with moc3023. to Master Trax: every pin is so busy and happy except for the sad and lonely pin4. please make pin4 happy by making it play with the others...Happy New Year to All.God bless!!
komentar [351]
kako da povrzam MOC3023 ima li nekoj idea i sema?
IP: 89.205.95.182
komentar [350]
Hello again Master Trax. i need to light an LED when lamp is off. i am thinking of tapping the signal coming out of pin 7 then input it to another pic interrupt pin to monitor if the light is on or off then light an LED when its off. But i noticed that in your circuit pin 4 can do this function. I know that your a busy person and have already given so much to many people. I am just going to try my luck (cross fingers) in asking if you will give us hex file for this. More power to you Master Trax!
komentar [349]
Jel možete staviti shemu zadatka?
komentar [348]
Its done!!!Im so happy!!Worked like magic. How much current can i still draw from the circuit? I was thinking of adding few RGB LEDs. Thank you so much Master Trax!!!!!!!!!
