komentar [16]
- Napisao trax na datum 27-04-2009 u 15:40:25
Ja sam koristio 150W bez problema. Snaga zavisi od triaca kojeg si upotrijebio. Procitaj
njegovu dokumentaciju, unutra pise koja je maksimalna snaga.
Broj download-a: 55,374
Ocjena: (3.00, glasova 8241)
http://www.embedds.com/the-homemade-ir-light-dimmer-v1-is-outstanding/
http://buzz.yahoo.com/article/1:make_magazine:57c35afdcfa43ef6a2f70653f6728d55/Compact-light-d
immer-with-IR-control
http://blog.makezine.com/archive/2009/02/compact_light_dimmer_with_ir_contro.html?CMP=OTC-0D6B4
8984890 http://www.elektronika.ba/617/ir-dimmer-svjetla-v1/
Koliko jake žarulje smijem staviti na ovaj sklop? Može li 180W? Hvala
Kako zastititi uredjaj od okretanja faze...? Koristio bih ga za stonu lampu, recimo... Hvala!
Try using 0.47uF capacitor instead of 0.39uF. And the resistor R1 must be in range of
47-100ohm.
Thanks trax today i complete remote learn ok it work fine but when i press manuly button for on
and off shortly bulub light full and after normal
and also for off. one bulb fuses by me in manually process,, any coments,,
sorry for my poor english
You can use 110V/60Hz version for HEX file, and use 220V components for the schematics! It will
work properly, don't worry!
imao sam modifikovan ir on/off i na njemu reprogramirao pic i izmenio pinove i sve je proradilo
iz prve.
da li nekome blicne led dioda s vremena na vreme? meni da ali nista drugo se ne desava.
Pozdrav i svaka cast!
hi,
first i thank for great project,anyone have experince with 220/60Hz what diffrent 50Hz and 60Hz
in this project please explain.my location is 2220/60Hz i cant find 220/60.hex
Ako ti je proradilo bez programiranja tipki, vjerovatno imas SAMSUNG TV kao sto je kod mene :)
