Broj download-a: 55,403
Ocjena: (3.00, glasova 8295)
komentar [197]
Hi GREAT PROJECT!!! I am working on a similar project for my own, and just cant make it work. Could u explain a little more on how u trigger TIC206 (setting 5v or 0v on the pic???) and why this value of resistor 820ohms for the gate? Was a disipator need it for the TIC206? The way u this components maybe could help me on my problem. THANKS IN ADVANCE
IP: 186.122.120.251
komentar [196]
Imam samo jos dva pitanja i necu vise: :) 1. Da li se moze povecati broj koraka na 15 nekako, u hex-u ili nesto, i da li moze da se napravi da dugim drzanjem ide recimo sekundu po sekundu korak po korak vise ili manje osvetljenja? 2. Koliko W moze da isporuci TIC?
komentar [195]
trax, replaces R2 with 330R +390 st in this series and work as normal, may have a problem? 470R can put in place, or better, and keep it that way, another thing he can control a fan?
IP: 201.68.253.9
komentar [194]
@ebicempre: i can't see that image. R1 and C1 should be close to those values noted in schematics. you have to experiment! maybe you didn't program your PIC correctly? WDT=off, PWRTE=on, INTOSC_NOCLKOUT=on, MCLR=off... maybe your soldering is wrong? put some pictures of dimmer so we can see it.
komentar [193]
trax thanks for the response, which values can subistitui R1, C1, R2, about the oscillation, I'm not using the dimmer bulb flourecente for, say, when he is near a place that has it oscillates Fluorescent tube too, I can use it to control fan or even lamps are common, thank you for helping me, otherwise I can use this scheme here to do a test that turns the problem of oscillation, so I will use part of the scheme's power circuit, the rest as in normal his scheme. http://www.rlocman.ru/i/Image/2007/11/02
IP: 201.68.253.9
komentar [192]
Evo, stigli delovi, medju njima i TSOP 31236 i sada radi kako treba... A onaj SFH sto pise u dokumentaciji da moze, ne moze :) Hvala trax i ostalima na pomoci, hvala puno. pozdrav, Damir :)
komentar [191]
@ebicempre; you can NOT use fluorescent lights with this dimmer! you can use only normal incandescent light bulbs! it seams that the dimmer doesn't have enough power, so that is why you see flickering on maximum power. try experimenting with the resistor value on GATE of triac, and also experiment with values of R1 and C1 !
komentar [190]
trax, please help me, as I said before, I made two designs go a dimmer worked normal when I turn the other until it reaches the maximum rate that the bulb still be sending control signal oscillates the bulb, I realized that if you leave the LED off this does not occur, what can be, I'm using a TIAC206M if can help me thank you, I noticed also that bind him in a place that has a lamp ballasts flourecente he is wavering endlessly, has some kind of filter that I use or mount if possible also if you have any s
IP: 201.27.202.191
komentar [189]
trax, I'm using a tic 206m ran normal the other is this happening, this turned into 110v 60hz, if you leave without the LED works normal but the time that he led the league and then oscillates to have any solution?
IP: 201.43.195.178
komentar [188]
@ebicempre: You must use the exact same TRIAC as in the schematics: TIC206. Also, I think that in Brazil you have 220V/60Hz system, so use 220V schematics and 60Hz HEX file!
Stranica komentara: <...1718192021222324...>
