Broj download-a: 55,389
Ocjena: (3.00, glasova 8269)
komentar [377]
Dear, Friend. I am trying to a light dimmer project like this one but using Contact buttons for each function (on e button for light UP, One button for light down, the other button for on/off). I need to have also the source code so I can change the functions. I am willing to pay for this project but my budget is very low. (I am a college student). Please send me quote at my email or Skype: NWSTM.COM and nwstm@yahoo.com Thanks a lot! Marlon
IP: 98.194.144.38
komentar [376]
Turgut, yes it is. In that case you will loose wall-switch functionality!
komentar [375]
Hello, Is it possible to mount hole circuitry in lamp cover at ceiling?
IP: 78.189.178.139
komentar [374]
hi friend,a person is selling your project in Argentina, I think that was not the purpose of publishing the development d. Here is the link is in Spanish. http://articulo.mercadolibre.com.ar/MLA-483664769-dm-control-interruptor-inalambrico-dimmer-a-c ontrol-remoto-_JM
IP: 181.29.179.128
komentar [373]
Zdravo Trax. Uradio sam sve po tvojoj sugestiji. Promenio polaritet izolacijskog trafoa, napajanje PICa je dobro filtrirano, otpornik 1M za detekciju nule smanjen na 10K, i nista. Isto se ponasa. Izludjuje me???
komentar [372]
Hello.My name is Paul and i am from Romania.firs of all your project is awsome!!!i buid the firs version and work ok but now i want to build the second version with dimmer and i want to use it on a powerfull led but at 12v and i don't know what is to do because i can't read the 50 hz from the network bbecause i want to use it on my solar baterry.i wonder if is possible to writte the code without reading the 50 hz...Thank you verry much
IP: 86.126.19.98
komentar [371]
Hvala Trax, probacu i javicu sta se desava, Pozdrav.
komentar [370]
I da, ovaj otpornik od 1M sto detektuje prolazak kroz nulu smanji na 10k. Ako nista od navedenog ne bude popravilo stanje, onda moras umjesto tog otpornika staviti sklop koji ce sa transformatora detektovati prolazak kroz nulu i na izlazu davati samo 0/5V. Ali o tom po tom...
komentar [369]
Na ovom izolaciskom transformatoru 220/12 Tr1, obrni "polaritet" na primaru ILI sekundaru. Znam da nema bas puno smisla ali probaj. Drugo, postoji mogucnost da ti se ovaj MOC3023 ne aktivira kako treba pa malo probaj nastimati predotpor od 470ohm, smanji ga na 330 ili povecaj na 560 pa vidi sta ce se desiti. Inace, sve ostalo se cini da je OK. Dodaj i neki elektrolitski kondenzator paralelno sa napajanjem PIC-a, mozda se on resetuje iz nekog razloga. Stavi i tri kondenzatora od 1n 10n i 100n paralelno sa pinom 1 i 8 sto blize PIC-u.
komentar [368]
A evo i sheme: http://tinypic.com/usermedia.php?uo=1LhMuIYoALxrxL\%2FcSjRYg4h4l5k2TGxc#.Umq83038K9I
