Broj download-a: 55,392
Ocjena: (3.00, glasova 8288)
komentar [267]
Vjerovatno nesto nisi dobro zalemio!? Ne smeta ti to sto si ukljucio CP...
komentar [266]
meni se uredaj ponasa kao i ovom marku tj. cim dimmer spojim na mrezu led dvaput blicne, pa mala pauza, dvaput blicne, pa pauza,... i to se konstantno ponavlja, sklop uopce ne reagira na daljinac, zarulja se upali malo duzim drzanjem tastera. PIC sam programirao sa Winpic-om i RCD prog. s ukljucenom opcijom CP(slucajno), koristio sam pic12f675 i TSOP1738. Neznam sta sad?
IP: 141.136.165.16
komentar [265]
Ne moze nijedan osim 12F629 i 12F675.
komentar [264]
može li se koristiti neki drugi pic, npr PIC16f628A ?
komentar [263]
Oh, i thought that the blinking was an error code :)
IP: 87.100.198.34
komentar [262]
@marko: No, I can't because I don't know. Maybe your switch is faulty, maybe you didn't program the PIC correctly, maybe your TSOP IR received is damaged, maybe there are electrical disturbances around the device... who knows.
komentar [261]
Hm, i'll try to troubleshoot it. But can you tell what all things that LED "bli bli...bli bli.." means?
IP: 87.100.198.34
komentar [260]
@marko: the dimmer will remember last brightness value when you turn it OFF by remote. when you turn the lights OFF by wall-switch, it will clear the memory and turn on at full brightness next time. You probably didn't program your PIC properly or there is a faulty component on your PCB! Be careful because there is 220V on the PIC at all times, even though it works on 5V!
komentar [259]
I used TSOP1736, and TIC206D, as recommended. And i did the wiring just like the instructions said for 230V/50Hz system. And by the way, a side note, if i turn the lights off completely(no power for dimmer), does the setting stay still in the PIC?
IP: 87.100.198.34
komentar [258]
@marko: If you notice that LED blinks even when you don't press any buttons on your remote control, it is probably because you used TSOP11xx instead of TSOP17xx receiver module. In that case, you will probably not be able to program your dimmer properly.
