Broj download-a: 55,392
Ocjena: (3.00, glasova 8288)
komentar [287]
Your brightness problem is probably because you aren't using correct parts in the circuit. This circuit works on 50 and 60 Hz without any problems. I don't know what is wrong with your device!
komentar [286]
ok then do i keep on using it with near \%60 capacity? is there anything to do with it? thanx
IP: 91.198.49.2
komentar [285]
You need to use TIC206 or TIC216 for this device! Anything else will not work properly. There is nothing that needs to be changed in software.
komentar [284]
ok, if it is the triac case 216, then is it possible to fix it with the software , i mean 12f675_50Hz.HEX for tic 216, is it the easiest way to repair it? and also posible? :) thanx
IP: 91.198.49.2
komentar [283]
I think mate that you have wrong triac...Which one you use...? I had the same problem with TIC216....
komentar [282]
hi all, i dont get the full brightnes of lamp after 10 levels up. i mean on number 1 button starts, i can say it is about nearly \%60 of the lamp. what is the problem with this. thanx
IP: 78.171.180.91
komentar [281]
spojio sam kao na semi i radi odlicno bilo kako da okrenem utikac, osim na produznom gdje je jos ukljucen tv i wii, onda kad preokrenem utikac lampa malo poludi i ne reaguje na komande. komponente koje sam mjenjao jer nisam imao kao sa seme su c1 o.36 i r1 85/4w ir tsop 1838 i mogu da primjetim da se sklop ne grije i radi bez greske. hvala
komentar [280]
upravo tako, gdje je faza a gdje nula to je nebitno. samo spoji sve kako treba po shemi a onda ustekaj lampu kako hoces.
komentar [279]
Nema ovo prijatelju ikakve veze sa fazom, samo ti spoji sve kao sto je u projektu i nema da brines za fazu...Mocices utikac da okreces do mile volje, ali samo ako povezes sve po PS-u, to jest kao sto je u projektu.....
IP: 178.222.27.90
komentar [278]
Pozdrav Moze li se kako ova shema prilagoditi tako da se spoji na lampu, a da ne razmisljam jesam li dobro okrenuo fazu.
