komentar [386]
- Napisao trax na datum 17-02-2017 u 14:48:16
Hi, you can use source code from the version V2, it is identical :)
Broj download-a: 55,389
Ocjena: (3.00, glasova 8269)
Dear friend, TIC206 is not available here, can I use BT136 or BTA016 instead
Hi,
i follow your project from several year when i start use pic microcontroller.
Due more powerfull caracteristics, i migrate to ATMEL AVR chip and now i would like to make a
code porting for ATTINY 8 pin series mcu. So i ask you if you can send me the source code of
your project. If you agree, on porting end, i can send you the file to publish on your
website.
Thank You in advance.
Luigi.
IP: 151.42.65.136
I control the Triac with an impulse that is synchronized when phase crosses a zero. This will
not work when powered from DC source, you must use AC.
Hi, just to explain further to my post below; I'll replace the triac with a transistor or fet
and power the circuit from 12v. The transistor will then control a 0-5v on the MV3340 control
pin, as I assume you are using pwm to control the triac?
IP: 105.0.64.93
Hi Trax, can one use this to control a MC3340p volume attenuator ic? It uses a 0-5v on it's
control pin.
IP: 105.0.21.46
I just checked, file can be downloaded and opened without problems. You need WinZIP to open it!
i cant open the file..please help me!
IP: 113.210.9.240
Hi Im Diego, I have to a dimmer IR, but with just two options, light up and light down, and i
cant use a PIC or any other Microcontroller if you can help me, i´ll thank you.
diegofelipe345@hotmail.es
IP: 186.155.136.157
IP: 186.155.136.157
