JAN17
Solid wood block digital LED clock
LED clocks are nothing special but this version sure is. In this version of LED clock all that you can see is a block of wood. Front side is drilled almost the whole way through so LEDs shine through the wood itself. This clock is not only a clock, it has an alarm function that will play your favorite radio station when it's time to get up in the morning. Besides that, you can also play games like Pong, Labyrinth and Jump.
Setting the time, alarm and playing games is done with Atari joystick controller. If you don't have Atari controller you can build one with a few pusbuttons. It is built with Arduino board with Atmel microcontroller.
© J_Hodgie
[ Source: J_Hodgie ]
- CharliePlexed RGB LED Dice (15-01-2009) [@News]
- LED VU-meter (07-03-2004) [@Schematics/Optics]
- WAP controlled automation (26-12-2008) [@News]
- Color-changing LED glowies (06-10-2009) [@News]
- Make your own LED from SiC (11-05-2009) [@News]
- Using LED as light sensor (12-06-2009) [@News]
- Interfacing LED matrix to Arduino (03-07-2009) [@News]
- Vibrobot Socbot - remote controlled micro robot (11-01-2009) [@News]
- Sundial LED clock (10-04-2009) [@News]
- Nixie tube propeller clock (15-07-2009) [@News]
