JAN10
GSM controller without microcontroller
If you are not familiar with microcontrollers but you still need some kind of DIY GSM controller, well, this is the thing for you. It consists of some cheap GSM phone that has "handset" port and can be configured to auto-answer incoming call, DTMF decoder (MT8870) and a few controlling relays.
When you call this GSM controller it will establish a voice connection. By pressing on any key on your phone's keypad, GSM controller will receive that DTMF signal and MT8870 circuit will set the appropriate binary value on it's data pins Q4..Q1. Those data pins will turn on or off relays connected to them. In order to expand number of data lines, you should connect SN74LS138 or SN74LS154 integrated circuit that will enable up do 12 relays to be connected and controller.
© unknownpocketnerd
- Introduction to PIC microcontrollers (05-03-2004) [@Documents]
- Motor speed controller (23-02-2004) [@Schematics/Everything else]
- GSM controller v1 (22-04-2004) [@Projects]
- Alarm with PIC microcontroller (20-02-2004) [@Schematics/Security devices]
- GSM phone ring detection (26-03-2007) [@Schematics/Everything else]
- GSM Phone Jammer Circuit Schematics (07-02-2012) [@News]
- Temperature controller (23-02-2004) [@Schematics/Everything else]
- Phoneline controller v1 (20-12-2007) [@Projects]
- SMS controller with AT90S2313 (24-08-2004) [@Schematics/Microcontrollers]
- Electronic combination lock with PIC microcontroller (20-02-2004) [@Schematics/Security devices]
