JAN7
Pressure sensor - cheap and homemade
If you ever need a pressure sensor, you can build your own from just a few components: two pieces of copper clad board, two wires and for the main ingredient you will need a conductive foam. Conductive foam is actually a sponge that you stick your IC's onto. That conductive foam has it's ohm resistance that depends on electrode's distance on it's surface. As the two plates come closer together, the resistance will become lower and that is the general idea. With this little sensor we get what is called a "force sensitive resistor" or FSR.
© kylemcdonald
- PIR sensor (20-02-2004) [@Schematics/Security devices]
- Ultrasonic sensor v1 (14-02-2004) [@Schematics/Security devices]
- Wireless XBee temperature sensor (25-11-2009) [@News]
- Ultrasonic sensor v3 (22-02-2004) [@Schematics/Security devices]
- DIY AC amp sensor for Tweet-a-Watt (21-12-2009) [@News]
- Alarm with 4 sensors (22-02-2004) [@Schematics/Security devices]
- Color sensor (23-02-2004) [@Schematics/Everything else]
- Make your own motion sensor (02-12-2008) [@News]
- Cheap water flow sensor (12-12-2008) [@News]
- Double sensor (11-09-2004) [@Schematics/Security devices]
