JAN6
Printing your PCB directly with InkJet printer
You have probably already seen this, but for those who didn't here is another method of making PCBs that gives the same results as photo-etching technique!
All that you will need is an old InkJet printer that needs to be modified to support printing directly on the copper-clad boards instead of paper. After the printer prints your design on the board, the key step is to cure the ink on 230 degrees Celsius in order to turn it into a strong acid resist. That is the key for successful PCB with this method.
Be sure to check the the source link for detailed explanation of this method.
[ Source: Volkan S., Stefan T. ]
- Circuit simulator and PCB design software - EasyEDA (17-03-2016) [@News]
- Build your own RFID tag (29-11-2008) [@News]
- PCBs for Warm Tube Nixie Clock v2 (03-12-2014) [@News]
- Double sided PCB UV LED exposure box (20-04-2009) [@News]
- How to make killer PCBs and solder paste stencils (21-04-2009) [@News]
- Make your own LED from SiC (11-05-2009) [@News]
- Connecting thermal printer with AVR (31-08-2010) [@News]
- PCB Designer (30-11-2008) [@Programs]
- Render PCBs with Eagle layout editor and POV-ray (31-01-2009) [@News]
- Timer for PCB exposure box with ATtiny2313 (07-11-2009) [@News]
- From zokasoft on 21-08-2021 at 13:29:20
Potrebno mi je napravit 3 štampane jednoslojne pločice dimenzije 122 x 72 mm.
Imam izgled štampe ali jpg formatu.
Zanima me i cjena.
Hvala.
